stuartmacg
- 28
- 6
- TL;DR Summary
- Earth in approx. radiative equilibrium with space (sun disk+4k elsewhere) => radiation out=in (taking account of sun angle to surface). Cold poles + fluid heat xfr => net effect of radiative coupling at poles is cooling. Loss of sea ice increases coupling at poles => should reduce earth temperature, and increase air/sea currents?
I seem to remember (physics degree 50 years ago) a kirchof law for thermal equilibrium under radiative coupling: an isolated black body will take the mean temperature of its surroundings. I have not found it on google search, so I am not sure I got the situation exactly right. Anyway using that and the sun's subtense and its surface temperature and 4k for the rest, you can get plausible figures for the equilibrium temperature of a flat surface in earth orbit, at different angles to the line to the sun. The average temp over a sphere is roughly right as you would expect.
Without heat xfr (air and sea) from the equatorial regions to the poles (and winter/summer transfer of retained heat), the winter polar regions would be 4k ... The polar regions are held above their radiative equilibrium level by heat from the rest of the planet.
If the loss of sea ice increases the radiative coupling of the polar regions to the cold space they see, I would expect this to increase their heat loss.
I am frequently told the loss of polar sea ice would heat the earth further, by TV etc. This seems implausible. If it is indeed correct, can someone please explain it to me.
PS how much does the heat flow from the earth's core raise the temperature? - I expect very little, still it is interesting to reflect that earth's radiative coupling to space reduces its surface temperature (from something which would melt rock) - we are not so much heated by the sun as cooled by the rest of the sky·
