How does trigonometry help determine the gravity component on an inclined plane?
Trigonometry is essential for determining the gravity component on an inclined plane, specifically using the sine function to find the parallel component of gravity. The discussion highlights that the correct answer to the problem is C, as it incorporates the angle of inclination, while A is incorrect due to its independence from the angle. Analyzing extreme cases, such as a horizontal or vertical plane, helps clarify the expected outcomes for the period of a pendulum-like system. The gravity component along the plane is expressed as g sin(60), which aligns with the behavior of a simple pendulum. Understanding these relationships and the role of trigonometric functions is crucial for solving related problems effectively.
jaewonjung
Question is in the file.
T=2pi root(l/g)
Since gravity is acting downward, I found the gravity component parallel to the plane, which was g/sin60.
I substituted g/sin60 for g into that equation and got D, but the answer should be C.
Look at it this way. Which of the choices (1) depends on the angle and gives the expected answer when the angle of the incline is, instead of 60o, (2) 90o and (3) 0o ?
Well, I know that A is wrong since it is independent of the angle. The other answer choices have an angle component.
In these sorts of MCQs, it saves time to think of the extremes - what happens if the plane were absolutely horizontal or completely vertical? What would the period be in those cases? Which of of the choices make sense in that light? You'll have your answer.
Thanks for the reply!
I see. If the angle was approaching 0, the period would approach infinity, since the pendulum would almost be completely horizontal and gravity would have a negligible effect. I understand why C is the answer and not D, but I still don't understand how to algebraically find the equation for the period.
Since the plane is frictionless, only the component of gravity along the plane matters, which is gsin60. It is then identical to the case of a simple pendulum where g is replaced by g sin60
Review your trigonometry that lead you to that conclusion.
