How Far is Charge C from Charge A When the Force on It Is Zero?
Charge C is positioned between charges A and B, which are 3.00 m apart, with A at +2.00 C and B at +3.00 C. The force on charge C is zero when the attractive and repulsive forces from charges A and B are equal. To find the distance from charge A to charge C, the equation F = k*Q1*Q2/r^2 is used, where the net forces from both charges must balance. The relationship between the distances from C to A (R1) and from C to B (R2) is established as R1 + R2 = 3 m, leading to the equation A/(R1^2) = B/(3-R1)^2. Solving this results in a binomial equation that can be approached numerically for the exact distance.
BuBbLeS01
Charge A and charge B are 3.00 m apart, and charge A is +2.00 C and charge B is +3.00 C. Charge C is located between them at a certain point and the force on charge C is zero. How far from charge A is charge C?
I am reviewing for my final and I can't remember how to do this! I wanted to use...
F = K*Q1*Q2 / r^2
But I can't have 0 in the denominator so I know I am missing something obvious...but I am not seeing it.
you're solving for when the NET force is zero. let A be charge of A, B be charge of B, and C for C, etc. distance d apart. so the distance from C to A is R1, and C to B is R2 then R1 + R2 = d.
and the 2 forces need to equal each other - i.e. F1 = kAC/(R1^2) = kBC/(R2^2) does that make sense?
Well yea but I don't have R2? So I tried using like R2 = 3- R1 but I can't get that to work...
thats how you have to do it, R1 and R2 are linked by the constant d (3 in this case). you'll end up with a binomial or something that you can solve numerically if nothing else.
