How far must the quarterback throw the ball?
  • Thread starter Thread starter Crusaderking1
    Ball
The discussion focuses on calculating the distance and direction a quarterback must throw the ball based on the receiver's movements and the quarterback's position. The receiver's final coordinates are determined to be (17, 27), while the quarterback is at (0, -7). The distance is calculated using the Pythagorean theorem, resulting in approximately 38.0 yards. The angle of the throw is found to be 26.5 degrees to the right of downfield. The calculations confirm the required throw distance and direction.
Crusaderking1
At Enormous State University (ESU), the football team records its plays using vector displacements, with the origin taken to be the position of the ball before the play starts. In a certain pass play, the receiver starts at +2.0 {i} - 5.0 {j}, where the units are yards, {i} is to the right, and {j} is downfield. Subsequent displacements of the receiver are +9.0 {i}(in motion before the snap), +10 {j}(breaks downfield), - 6.0{i}+ 4.0 {j}(zigs), and +12.0{i} + 18.0 {j} (zags). Meanwhile, the quarterback has dropped straight back to a position - 7.0 {j}.How far must the quarterback throw the ball?
In which direction must the quarterback throw the ball?
Probably Rx+Ry=R
I drew the diagram.
Do I have to use two triangles to figure this out, then add those vectors, or something? I would find the components but I don't have any angles to work with(that I know of).
Did you guys have the receiver end on coords (17,27) and the QB on coords(0,-7)?
(17)^2+(34)^2, then square root = 38.0 yards
tan-1 (34/17) = 90-63.43 = 26.5 degrees to right of downfield.
Is that right for yards. Doesn't seem right.
Thanks!
What's the question?
How far must the quarterback throw the ball?In which direction must the quarterback throw the ball?
Alright, I figure out this is correct.
