How High Can a Salmon Jump if It Leaps at 2.5 Meters Per Second?
To determine how high a salmon can jump when it leaps at 2.5 meters per second, one can apply the equations of motion and consider gravitational acceleration at 9.81 m/s². The relevant formulas include V final = V initial + A(t) and X final = X initial + V initial (t) + 1/2A(t²). It's suggested to also approach the problem using conservation of energy, where the kinetic energy of the salmon converts into potential energy during its jump. By calculating the maximum height using these principles, one can find the answer to the question. Understanding these equations is essential for solving similar physics problems.
mandaa123
If a salmon swims straight upward in the water fast enough to break through the surface at a speed of 2.5 meters per second, how high can it jump above water?
i don't know, because all i know is speed.
is acceleration 9.81 in this? i don't know how to figure it out : [
the formulas you need are:
and
X final = X initial + V initial (t) + 1/2A(t^2)
where x is distance, v is velocity and a is acceleration (yes, 9.81 m/s^2)
write'em down, I'm sure they're in your book, and should get you started on all your problems.
You may as well approach the question from the conservation of energy side. Kinetic energy gest converted into potential during flight.
