- #71
Richard R Richard
- 82
- 45
The distance between two points on a circle is a chord. The arc of circumference between these two points is always longer than the chord. When the tire hits the ground, the circumference is elastically compressed, to reduce its length from the arc measure to the chord measure.
If we define a forward direction and turn to the left, the compression on the left side of the tire will be less than on the right side, just enough to absorb the difference in turning radius.
As long as the area or weight differential over the area differential, multiplied by the mean coefficient of friction, does not exceed the maximum static friction force, integral over the tread area of the mean pressure per unit, there will be static frictional force with a component perpendicular to the speed of the car, that will be the maximum centripetal force without slip.
If the tire demands more, with tight curves, adding more load by weight or by aerodynamics, etc., then, there may be "also" a dynamic friction force, which opposes the relative sliding of the tire with respect to the ground, whose direction is a combination of the speed of the car and the tangential speed of the tire (it can be higher if you accelerate, the same if you only turn, zero if you skid, or retrograde as very few drivers know how to achieve).
To pretend that all the centripetal force is caused by the sliding friction of the tire, in my opinion is an error, easily demonstrable.
In the 500 miles more than half of the trip, the vehicle is turning, although there is cant, the tire forces in a centripetal direction during each turn, thus lasting approximately 100 miles. But can you imagine how long a tire lasts while sliding it 100 miles, even though I changed the speed of the vehicle very little? They are different demands.
A city car will be doubling 2% of the route with a duration of 60000km, it would be the equivalent of dragging it 1200km… and it is clear that this last wear will be higher than the previous one.
That is my point of view, static friction is always one or two orders greater than dynamic, and only in severe conditions of use, is it the main cause of wear, together with those derived from acceleration or braking. A vehicle on the road where there are curves that are longer, it wears less than in the city, where the turns are short and slower. But on the road more length is covered by doubling than in the city, so the dynamic friction would not correspond to the wear.
