How is twin paradox resolved in case of no/zero acceleration?
In summary: I mean you can make it algebraic, but it's no longer a paradox. One is a non-inertial path, the other is an inertial path. You're not comparing apples to apples. You're comparing apples to oranges, but then the path of the apple is different from the path of the orange. There's nothing that remains that is paradoxical by the standards of special relativity. There isn't anything that remains that would lead to a contradiction, as in the usual formulation. You could make a special non-accelerated version of the paradox by using 3 clocks (A, B, C) instead of 2 twins. Clock A stays behind representing the stationary twin. The two other clocks are
  • #36
lovetruth said:
If each twin observes other twin's time to be dilated, how can their time be same?
They aren't the same, they are symmetric. You don't seem to understand symmetry.
  • #37
tiny-tim said:
people who are further away look smaller :wink:
if A is a long way from B, then A says "B looks smaller", and B says "A looks smaller" …
where's the paradox??
Excellent example of symmetry!
  • #38
Hurkyl said:
You cannot resolve a paradox by justifying one half of the contradiction. You have to explain why the other half of the contradiction is invalid.
A resolution of the twin paradox has to explain what is wrong with the argument
Stella sees that Terra is moving with respect to her, and thus her clock running slowly for the entire trip. Therefore, when Stella returns home, she finds that Terra's clock reads less time than Stella's clock does​
Showing an asymmetry does not demonstrate a flaw with the above argument. It simply defeats the supplementary argument that Terra and Stella's points of view are indistinguishable.
One can hope that demonstrating the asymmetry, or that providing a correct way to compute things, could prompt the confused person into resolving the the paradox himself. But you also risk the rather dangerous possibility of pushing the person into accepting doublethink -- to accept the resolution despite retaining the belief that there is nothing actually wrong with the argument above.
So, if I understand you correctly, you are saying that people who wants to resolve the paradox and are shown, quantitatively, that the Lorentz transformation of suitable events can explain and give the actual number of the difference in the twins age, these people will still in some meta-physical way believe there is a paradox unless they are presented with a much more complicated explanation that includes acceleration? If so, I don't find that very plausible. There is no doubt that changing from an outbound to an inbound trajectory is central to the resolution, but exact nature of this change is (in my book) not essential.
I don't think I can bring anything new to this discussion at this point, only repeat what I have already said. You seem to skip or ignore the specific questions I've ask you so far, so unless you feel like answering some of them I really don't see us getting any further.
  • #39
Yes. You are explaining to them information they already have (Terra ages more than Stella), and offer absolutely no insight as to why other information they have (Stella ages more than Terra) is faulty.
That would be even worse!
I've answered everything I thought was relevant. But since you insist:
What I have been claiming, though, is that is that with regard to the calculation of proper time intervals for the two twins you can consider the three-clock scenario a limiting case of the accelerated scenario where the acceleration is arbitrarily high. Do you disagree with that?
I agree in the sense that you are considering two identical mathematical calculations. I disagree in the sense that three clocks is not a limiting case of two clocks.
it would also be nice to know if you consider the explanation using Minkowski diagram a valid resolution of the paradox?
It depends on what you do with the diagram. Wikipedia's resolution is fine. It sports a feature your argument does not -- a demonstration of where and how the rationale "Stella sees Terra's clock running slowly the whole trip" is faulty.
Was there another question youw anted answered?
  • #40
Well, I think I can see what you are getting at then. You are worried that by only showing the three-clock scenario with its associated simple calculations people would still be at loss as to the nature of the break in symmetry, that is, they would still not know the "reason" for why Stella ends up younger and not vice versa. In the words used on the Twin Paradox FAQ [1] the three-clock scenario leaves a "time gap" which I do concur seems very mysterious unless it is also explained what it "really looks like" in a scenario with acceleration.
If this was your point, then I agree. Personally I feel that the three-clock or instantaneous turn-around scenario explains a lot and that change of reference frames itself is the essential part, but I can see why some would feel something important has been left out. If I were to explain this to, say, my 15 year old kid I'd show her the three-clock version with its simple calculations and then in parallel or afterwards extend the explanation (but not the calculations) to include acceleration of material bodies so that we could make an actual twin take the trip. In fact, this would be a fun vacation exercise.
Not unless you think I've missed your point above.
[1] http://math.ucr.edu/home/baez/physics/Relativity/SR/TwinParadox/twin_paradox.html
  • #41
there would only be a paradox if A was standing next to B (or if they were moving past each other, but they make their measurements at the exact moment they are passing) …
then it is paradoxical for each to regard the other as shorter
(of course, that paradox does exist … it's called the Lorentz-Fitzgerald contraction! :biggrin:)
similarly, there's no clock paradox unless the two clocks start at the same velocity, and finish at the same velocity (position doesn't matter) :smile:
Distant object looks smaller because they subtend smaller angle in the eye. Distant object looking small is just an optical illiusion, the object still has the same size. Do you believe that distant star comes closer when you see through telescope?
  • #42
Symmetry is a property of geometrical figure having a mirror plane.
Time is a scalar quantity.
Saying time is symmetric is like comparing oranges to apples.
I don't get what you mean by time is symmetric. Perhaps you can express it mathematically what symmetric time means?
  • #43
Clearly. But why do they BOTH subtend smaller angles? How come one doesn't subtend a smaller angle and the other subtend a larger angle? The answer, unsurprisingly, is symmetry.
Symmetry is more general than that. Mathematically and physically symmetry means that something does not change under some specific transformation. For instance, an equilateral triangle is symmetric under 120º rotations about its center because it is unchanged by that transformation.
In the case of the example above with distant objects, A and B, looking at each other the angle subtended is determined by Euclidean geometry which is unchanged by rotations and translations. Since A and B are related to each other via a rotation and a translation they are symmetric, meaning that the geometry is also unchanged by transformation of swapping A with B. Therefore, if the angle subtended by A decreases for B then by symmetry we can swap A and B and state that the angle subtended by B decreases for A.
In the case of relativity (either Galileo's or Einstein's) it is a fundamental postulate of the theory that the laws of physics are unchanged by boosts. So if A and B are related to each other via a boost then they are symmetric and in any statement you can swap A and B and have an equally valid statement. So if A's clock is slow according to B then by symmetry B's clock is slow according to A.
Do you feel like you understand the important role of symmetry a little better now?
  • #44
lovetruth said:
… Distant object looking small is just an optical illiusion, the object still has the same size.
Yes, and a moving clock going slower is also just an optical illusion …
do you really think that a moving (non-accelerating) clock is actually going slower? :rolleyes:
btw, the Lorentz-Fitzerald contraction is an optical illusion too …
do you really think that a moving train actually changes shape? :wink:
  • #45
I don't want to be pedantic here, since I agree with essentially everything you have said. However, I don't like your usage of the word "actually". It seems to present the idea that something is a particular way objectively. And speaking about SR, since essentially every interaction is mediated by photons, I am okay with saying that these phenomena are "optical" (the measurements/interactions/observations are all described by classical optics) however, deep down there is no pure version of the train. But, I am willing to hear out a counter argument to this idea if you think different.
  • #46
tiny-tim said:
Hi San K! :smile:
no meeting of the twins, no paradox …
they have to start and finish together (or at least at the same velocity) to be able to compare ages at the same time
No, just have them take pictures of themselves they can compare later when they meet up again. :) same result will happen though. The spaceship twins picture will show him ageing at a slower rate.
  • #47
No, this is false. While each is moving away from the other, pictures will be identical. Again, think about symmetry. Just as each sees the other getting smaller, each sees and photographs the other's clock going slower.
The symmetry goes away only if one of the twins changes direction. Then, the one that changes direction immediately sees a change in clock rate of the other; while the one that remains inertial only sees the other change clock rate after a delay. This is what would lead to a consistent correlation of the movies after both twins are together again.
  • #48
This is not ever true in any scenario, regardless of their motion. How could it possibly ever be true? If they take a photo every year according to their own clocks then they will be a year older in every photo.
In the standard twins paradox (or any other asymmetric scenario) what will differ is the number of photos, not the apparent age in the nth photo.
  • #49
Good point PAllen and DaleSpam. That's what I was thinking.
The time-space for both, Earth and ship, are different.
Now if we take photos according to a third stationary (or for that matter the stationary "earth") clock say at times...noon, 1 pm, 2 pm...etc i.e. per the Earth's clock time and for now ignore the clock time on the "moving" ship.
a) what would we notice about the photos?
if we take photos per the "moving" ships clock and ignore the "stationary" Earth's clock time
b) what would we notice about the photos?
Note: I know that that comparing photos this way might not be "complete" (for the purposes of showing the consistency of relativity) since we are not accounting for other things.
  • #50
A clock doesn't make a reference frame -- you need a way for observers to decide what the clock says "now".
e.g. if Stella flies past the sun and uses her telescope to look at the clock on Earth, when does she take the "1 PM" photograph"? When she sees "1:00" on the clock through the telescope? When she sees "12:52" (minus a few seconds)? Some other scheme?
(note: The sun is just over 8 light-minutes away from the Earth)
  • #51
- by "now", do you mean to say both the frames of references (terra's Earth and stella's ship) have to agree on what is "now"?
i.e. they have to be at same speed/velocity?
- the photons that hit Stella's telescope at 1:08 pm would show 1 pm?, however there is some point you are trying to make, what is it? Stella's clock would say something like 12:30 pm?
note: the 1:08 pm is per the clock's time on earth/sun/Terra (or any other object that is "stationary" with respect to earth/sun) and not on Stella's ship
  • #52
hi jfy4! :smile:
jfy4 said:
… your usage of the word "actually". It seems to present the idea that something is a particular way objectively.
i think we're basically in agreement
as a solid life-form, i have a prejudice in favour of rigidity (or form) …
i consider that for something to be real, it must at least be rigid, it must have a particular shape …
my prejudice tells me that a square rigid object must still be rigid when it is moving (even if it is no longer square) …
but the Lorentz-Fitzgerald contraction makes it a rectangle, and the shorter side changes if you rotate it 90°
that's not rigid!​
so i say that the contraction is an illusion, and the original square is the objective reality :smile:
  • #53
don't they have to simply finish at the same velocity? ...start at same velocity not required?
  • #54
required
  • #55
tiny-tim said:
required
you mean...same time duration and same velocity at start and stop?...got it
because this would mean same time dilation (degree and duration combo) etc
a requirement for things to be symmetric (a term that I newly discovered here)?
  • #56
This is a terrible argument. By this argument liquids and gasses are not real. In fact, a person who loses a limb or even goes on a diet is not real. Argument by prejudice is never valid, but this is a particularly bad one.
Also, illusions are not measurable. They are when your senses, particularly vision, disagree with what is measurable. So length contraction is not an illusion.
  • #57
There is too much left unspecified to answer this directly. Basically, to determine the age of something, or the reading on a clock, you simply calculate the proper time.
http://en.wikipedia.org/wiki/Proper_time
The proper time is invariant, so you can calculate it in any frame and all frames will agree.
  • #58
Let's take a new case (please see the analysis below and feel free to suggest modification):
A rocket moving at a constant velocity of, say, 80% speed of light between Earth and sun, towards the sun.
on Earth Mr. E is sitting with his clock
on Sun Mr S is sitting with his clock
on rocket Mr R is sitting with his clock
R says to both S and E (separately) that you are the ones that are moving with .8c
R says that E is moving away, from it, at .8c and S is moving towards it at .8c.
Thus from R's perspective/Frame-of-reference the clocks on E and S are moving slower.
E and S agree that the distance between them is constant and neither is moving.
Correction: E and S agree that the distance between them is constant, however they cannot say, for sure, that neither is moving. All they can say is either both are moving at same velocity or both are stationary. i.e. the relative velocity between them is zero.
Now all three (E, R and S) are correct because they are in different frames of references that are not comparable.
If apple says I am more redder than the orange is oranger ...how do you compare?
To compare you have to bring them to the same speed/velocity (plus you have to know the earlier conditions speed etc to make exact calculations on time dilation).
When we bring them to the same speed and do the time dilation calculations all three E, R and S will agree and there would not be any contradictions/paradox.
  • #59
San K said:
how do you compare?
Using the Lorentz transform:
http://en.wikipedia.org/wiki/Lorentz_transformation
At this point, you should probably take some time to learn the basics of the Lorentz thransformation and also invariants such as the spacetime interval. Your recent questions seem more like random flailing around than a directed and purposeful line of questioning.
  • #60
If Stella didn't accelerate much, so she was moving "slowly" relative to Terra, then yes, if Stella is near the sun when her clock reads 1:08 PM, her telescope will see photons from Earth that read 1:00 PM, and she would measure the Earth-Sun distance as being 8 light-minutes.
"Slowly" means that all numbers are small enough that Newton mechanics still holds approximately. So you can still pretend there is an absolute notion of time and of simultaneity.
However, if Stella took off at a somewhat faster velocity, things would be different. At a certain rapidity, if she takes off at noon, she would find her clock reads 12:02:00 when she passes the Sun. At this instant, her inertial reference frame reckons that Earth's clock reads 12:00:28. Through her telescope, she sees a reading of 12:00:14 on Earth's clock.
However, the Terra's inertial reference frame reckons that Stella passes the sun when Earth's clock reads 12:08:33. (Of course, it agrees that Stella's clock reads 12:02:00 when it happens)
If Stella were to take a picture when her clock reads 12:02:00, how does she label the picture?
  • This is a picture of me at 12:02:00
  • This is a picture of me at 12:00:14
  • This is a picture of me at 12:00:28
  • This is a picture of me at 12:08:33
  • Something else?
That it makes no sense to say things like "do something when Earth's clock says noon" unless you are actually on Earth. You need to include some way of deciding precisely when Earth's clock says noon.
  • #61
You are right that both twins will observe Time Dilation according to SR. No doubt.
But you can not see the PARADOX. A twin will see that other twin is younger than him. So both the twin will see different reality or things.
Twin A will see that he is older than B. Twin B will see that he is older than A.
But reality is unique and can not be relative otherwise, the concept of "personal reality" should be there which is absurd.
  • #62
Time dilation & length contraction are real not illusion.
Yes the train length will shorten really.
  • #63
No, it's not. Each twin will see the other as younger and that is reality. As long as the two twins never get back together, at the same place with 0 relative speed, there is no paradox.
  • #64
In this case which twin is older is a matter of perspective (I.e. Coordinate dependent), and does not have anything to do with the uniqueness of "reality".
If there were two fans watching a race from opposite sides of the road and one saw that the racers went left while the other saw that the racers went right, would you complain about PARADOX and "personal reality", or would you simply recognize that the direction the racers ran is coordinate dependent?
  • #65
So you both are suggesting that reality is frame dependent.
Is it not equivalent to multiverse. Every observer living in his own world different from that of another.
Consider this: You see that a man has died but the man sees that he is alive. Is this not a paradox.
I think there is only one universe and a single reality. Everyone sees the same.
  • #66
Reality is not frame dependent. Observations of reality are frame dependent. Fortunately, we happen to know how to transform observations from one frame to another.
  • #67
Depends on if the man sees himself still alive "when and where" you see him dead. That would be a parodox. IOWs, you see the man die when the man's own wristwatch read 7/21/11 12:00pm. If the man "holds himself alive" when his own wristwatch read 7/21/11 12:01pm, that would be a parodox. On the other hand, if the man holds himself alive when his own wristwatch read 7/20/11 3:01am, then no parodox, no problem.
Per STR, the man can be reported by others as both dead and alive, but not by any single observer. If you and I execute a flyby, with you at rest with the man and I at luminal speed wrt the man, ... then upon our flyby event, you can later prove he was deceased per you (his clock may have read 7/21/11 12:01pm) and I can later prove he was still alive per me (his clock may have read 7/20/11 3:01am). When we are momentarily colocated, I see the man as 9 hr younger than the dead man you see, but the same man none the less. I will also be able to prove that "later", when the man's clock read 7/21/11 12:01pm per ME, he had just died. This would be consistent with what you saw, and consistent with a single reality.
That's what STR suggests as well. One reality, differing points of view.
GrayGhost
  • #68
As I have discussed in the previous posts that Twins with no acceleration will see that they are older than their counterpart.
The views of both the Twins will not be consistent. They will not agree on who is more older. This means they are living in different realities or world or universe(interchangeable terms). Their observations are not same. Thus a concept of reality as unique or observe-independent is shattered.
Consider this paradoxial situation: Twin A sees that he is an old man while twin B is still a baby. Twin B sees that he is an old man while twin A is still a baby.
  • #69
There is no paradox. By transforming the observations from the frame of Twin A into the frame of Twin B, we find that both observations are consistent. Which is what I said to begin with. Observations are frame dependent. QED
  • #70
I haven't read the previous posts in depth, and you failed to provide a link to which post in this long thread you're referring to. But if you think there is some inconsistency here, you're sill wrong, whether or not you've previously posted the wrongness. But it's a bit hard to tell exactly where y you're going wrong if you're just saying that "I still say that", repeating some previous incorrect conclusion, rather than providing the details. But this leads to another meta-issue.
You don't give the impression of to be actually trying to understand what's going on, (as per your remarks about "I've said this wrong thing before", as if it proved something), you seem intent on reiterating your wrong views rather than learning something.
As far as what you did say, it wouldn't be paradoxical for twin A to conclude that he was old and B was a baby, and vica-versa, if they are spatially separated and using different definitions of how to compare there ages.
For instance see https://www.physicsforums.com/attachment.php?attachmentid=37080&stc=1&d=1310342900
One twin uses the red lines to compare simultaneous events, another the green lines. So each can say that they are younger than the other, according to their method of comparison.
And there isn't a case where an actual pair of real observers (and not some composite created from the view of multiple real different observers, said composite being generated using additional assumptions that need to be gone into) that actually observes what you describe. So the case you describe would be a paradoxical, however it doesn't actually happen that way (unless you count the case I mentioned above, where one twin uses the red lines and the other the green lines). Which is most likely what people have been trying to tell you all along, and I'm guessing from your remarks about having "posted this all before' that they've tried to correct you before.
