How long will it take to boil 1 liter of water?
  • Thread starter Thread starter EMEE_
    Boil Water
To calculate the time required to boil 1 liter of water from 20°C to 100°C using a kettle with 85% efficiency and 200W power, the energy required is correctly calculated as 334,400 joules. To find the time, the formula t = E / (P * η) can be used, where E is the energy needed, P is the power, and η is the efficiency. Given that 1 watt equals 1 joule per second, the effective power after considering efficiency is 170 watts (200W * 0.85). This leads to a time calculation of approximately 1963 seconds, or about 32.7 minutes, to bring the water to a boil. Understanding these formulas and conversions is crucial for solving similar problems.
EMEE_
How long will it take to boil 1 liter of water from 20°C? The heat efficiency / η is 85% , voltage / U 230V and power / P 200W. The answer must be given in seconds.
Hi.
I have been trying to solve the following problem:How long will it take to boil 1 liter of water from 20°C? The heat efficiency / η is 85% , voltage / U 230V and power / P 200W. The answer must be given in seconds.
So,
t1 = 20°C
t2 = 100°C
Δt = 80°C
V = 1,0 liter → m = 1,0 kg
ηkettle = 85%
U = 230V
P(the power needed to boil water) = 200W
So far I have solved the energy consumed in boiling water: E = c * m * ∆t = 334400_J (joules) Have I used the right formula? And what formulas can I use?
Hopefully, someone here can help me!
Are you just supposed to bring it to a boil (begin boiling) or boil it all away?
I'm just supposed to bring it to a boil.
Then your calculation of the energy required looks correct. Do you know how to go from there to the time required? You will need to use the input power and efficiency.
Ok, good if the calculation is correct! :). But I don't actually know how to go from there to the time required...
Hi EMEE:
Does it help to know that a watt is a joule per second?
Regards,
Buzz
Buzz Bloom said:
Hi EMEE:
Regards,
Buzz
Yeah, thanks, that might help. But I don't really know what formulas/ equations I should use... Could you please help with those?
If I'm going 50 miles per hour, and I have 300 miles to travel, how long will it take? If I'm putting in 200 Joules per second, and I need 334400 Joules, how long will it take?
17K
  • · Replies 18 ·
22K
