How to Configure a Power System for High Current and Low Voltage Demands?
Configuring a power system for a furnace requiring 50KAmps at 100 volts is complex and demands expertise. The discussion emphasizes the necessity of using transformers and thyristors for such high current applications. Participants stress the importance of involving licensed electricians and electrical engineers due to the risks associated with high power systems. Regulatory permits and insurance considerations are also highlighted as critical components of the project. Seeking professional engineering assistance is strongly recommended to ensure safety and compliance.
Jhon Paul
I have to configure a power system for a furnace which demands very high current of the order of 50KAmps with low voltage of the order of 100 volts.
Can anyone help me to get insight into how to configure the power system in boarder way.
I am planning to use a transformer with thyristors .
That's a lot of power to be dealing with for the first time, Jhon! How did you end up with this assignment if you have not worked with such systems in the past? What kind of systems have you worked with so far? What regulatory permits and inspections are required for this industrial system? What do you need to do with your company's insurance carrier to get the final system signed off?
Whoa! That is a huge current. In power plants, we use isolated phase bus ducts for half that much current.
Interrupting such currents is very difficult. If not done right, the fire and explosion can destroy the whole facility and kill people.
This is not a topic to ask strangers about on an Internet forum.
Likes Asymptotic and berkeman
Well presently I am using a power supply with 3KAmps under 30 volts. So though I don't claim I have the expertise on power system but yes I am familiar with the stuff. Next I am just looking on the architecture not to build the power system. Thats why I just mentioned if anyone have knowledge of bigger power unit can reply. back.
My advice is to contact an engineering firm with the requisite experience. Your application is outside of mine, but a lot of detail work goes into building a successful 5 MVA power controller.
Likes russ_watters and berkeman
That is an enormous amount of electricity. Designing and working on such systems requires licensed electricians and electrical engineers. Please find qualified people to do this work for you. Thread locked.
Likes Asymptotic, davenn and berkeman
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
