- #71
Elias1960
- 308
- 123
I don't understand why this would be a problem. It is, as mentioned, physical level proof, many things which a mathematician would have to specify and prove will be simply ignored as trivialities. Here, the critical part is clearly the interaction term and not the Hamiltonians of the parts.A. Neumaier said:Thanks. But p. 180 has no proof at all, and the outline at the top of the next page makes the (in general unwarranted, see post #42 above) assumption that one can neglect both the system Hamiltonian and the detector Hamiltonian and that one may therefore only consider the interaction term.
At some point. This point may be far away. To propose models beyond effective theory (QED is itself an effective theory, and as an effective theory does not need a model of itself) which would give QED in the large distance limit smells like ether theory, thus, is essentially a no go today. So, even if they would exist in the literature, they would be ignored and possibly could not even be discussed here.A. Neumaier said:Well, we are reaching experimentally smaller and smaller distances. Thus preferred frame effects should at some point become observable. When depends on the actual model you propose for an effective QED. None exists in the literature, there are only toy theories that significantly deviate from QED even in the large-distance limit.
