How to determine the power of this circuit?
The discussion revolves around calculating the power of a circuit using nodal analysis, with the textbook providing a power value of 100 W. The user detailed their calculations, arriving at a power output of 98.4 W based on their input current of 4.92 A and a voltage of 20 V. Another participant confirmed the user's calculations were correct, noting their own result of 4.91 A using the same method. Additionally, a suggestion was made to utilize an online circuit simulator for further practice. The conversation highlights the importance of accurate calculations in electrical engineering problems.
Leonid92
Determine power of the circuit (Fig. 1), if voltage U = 20 V, resistances of branches: r1 = r4 = 5 Ohm, r2 = r3 = 2 Ohm, r5 = r6 = r7 = 6 Ohm.
U(input) = A*U(output) + B*I(output)
I(input) = C*U(output) + D*I(output)
A*D - B*C = 1
In "Homework Equations" field, I wrote general equations for quadripole.
I have doubt about the solution. True answer given in the electrical engineering textbook is P = 100 W.
Here is my solution:
1)
In scheme, I pointed currents and U(output) (Fig. 2).
2)
U = A*U(output) + B*I2
I1 = C*U(output) + D*I2
A = 1 + r1/r3
B = r1 + r2 + (r1*r2)/r3
C = 1/r3
D = 1 + r2/r3
3)
U = A'*U(output) + B'*I6
I5 = C'*U(output) + D'*I6
A' = 1 + r5/r7
B' = r5 + r6 + (r5*r6)/r7
C' = 1/r7
D' = 1 + r6/r7
4)
U(output) = I(output)*r4
5)
U = A*I(output)*r4 + B*I2
I1 = C*I(output)*r4 + D*I2
U = A'*I(output)*r4 + B'*I6
I5 = C'*I(output)*r4 + D'*I6
I(output) = I2 + I6
6)
U = A*(I2 + I6)*r4 + B*I2
I1 = C*(I2 + I6)*r4 + D*I2,
U = A'*(I2 + I6)*r4 + B'*I6
I5 = C'*(I2 + I6)*r4 + D'*I6
7)
A = 3.5
B = 12 Ohm
C = 0.5 S
D = 2
A' = 2
B' = 18 Ohm
C' = (1/6) S
D' = 2
8) Substitute numbers into the system of equations:
20 = 29.5*I2 + 17.5*I6, (1)
I1 = 4.5*I2 + 2.5*I6, (2)
20 = 10*I2 + 28*I6, (3)
I5 = (5/6)*I2 + (17/6)*I6, (4)
(1) - (3):
19.5*I2 - 10.5*I6 = 0
I2 = (21*I6)/39
(3):
20 = 10*(21*I6)/39 + 28*I6
I6 = (130/217) A
I2 = (21*I6)/39 = (10/31) A
(2):
I1 = 4.5*(10/31) + 2.5*(130/217) = 2.95 A
(4):
I5 = (5/6)*(10/31) + (17/6)*(130/217) = 1.97 A
9)
I(input) = I1 + I5 = 4.92 A
10)
Power of the circuit:
P = I(input)*U = 98.4 W.
Is it right solution?
In the textbook, many answers are rounded, so the answer I obtained does not contradict the answer specified in the textbook.
Leonid92 said:
Homework Statement: Determine power of the circuit (Fig. 1), if voltage U = 20 V, resistances of branches: r1 = r4 = 5 Ohm, r2 = r3 = 2 Ohm, r5 = r6 = r7 = 6 Ohm.9)
10)
I solved the problem with nodal analysis, and I got I(input)=4.91 A. Your solution looks correct.
Likes Leonid92
Hi
I thought I might add this quick and easy online circuit simulator, that would help you when practicing questions:
https://www.falstad.com/circuit/
Likes Leonid92
