How to find the current in the no resistor wire?
To determine the current in a wire without a resistor, it's essential to first calculate the total resistance and current in the circuit, which has been done, yielding a total current of 0.1344A using the formula V=IR. However, to find the specific current in the no-resistor wire, a detailed analysis of the circuit configuration is necessary. Participants emphasize the importance of showing an attempt at solving the problem before receiving further assistance. This approach ensures that the discussion remains focused and constructive. Providing a clear step-by-step solution is crucial for effective help.
qpzm77gg
I can't find the current in the following picture, please help me to find it and show the step, thanks.
You must show your attempt at an answer before we can help.
I can find the total resistance and then I found out the total current is 0.1344A by V=IR.
But I can't find the current in the no resistor wire I which the question need to find it.
Show your work.
PF rules:
You MUST show that you have attempted to answer your question in order to receive help.
Any and all assistance given to homework assignments or textbook style exercises should be given only after the questioner has shown some effort in solving the problem. If no attempt is made then the questioner should be asked to provide one before any assistance is given.
