How to get from pump flow rate to pressure change
To achieve a pump flow rate of 40 gallons per hour to a height of 8 feet, a pressure change of 3.44 psi is required, as calculated using the Bernoulli equation. However, the available pumps listed have a maximum head lower than the needed 8 feet, making them unsuitable. Simply increasing the flow rate will not compensate for inadequate head capability; a pump must be able to deliver at least 8 feet of head. Redesigning the piping system to minimize head loss is another potential solution. The discussion also raises a question about the relationship between flow rate and head height in pump performance.
zzinfinity
Hi,
Essentially what I need is a pump that will pump 40 gallons of water per hour to a height of 8 feet. Ignoring pressure losses in the lines (for now) I used the bernouli equation to determine that I need a pressure change of 3.44 psi in my pump. I found these pumps that look suitable but all list a max head far lower than the 8 feet I need. http://www.drsfostersmith.com/product/prod_display.cfm?pcatid=21414
I was thinking maybe just use one with a higher volume flow to compensate for the head loss. Maybe the 100 gph one? Is there a way to determine exactly what I need? Thanks!
If the pump cannot deliver a head greater than 8', increasing the flow will not compensate. Find a pump which can deliver at least 8' of head, or re-design the piping system to reduce the head loss.
Fascinating. Fluid mechanics has always baffled me. Thanks!
Out of curiosity, is there a fundamental reason why a pump that can pump 200 gph to a height of 5 feet, can't also pump 100 gph to a height of 10 feet?
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
