I Hubble relation to Scale Factor
In a hypothetical Universe where the Hubble parameter is constant, the scale factor can be derived using the equation H(t) = dot(a)/a, leading to exponential growth. Calculating with a Hubble parameter of 70 km/s/Mpc suggests that the Universe was about one third of its current size 14 billion years ago. However, this raises a contradiction regarding the Hubble time, as it implies a constant Hubble time of 14 billion years, which should not align with a smaller scale factor. The discussion highlights the need to derive the scale factor from the Friedmann Equations for a more accurate understanding. The confusion stems from misinterpretation of the curriculum, emphasizing the complexity of learning cosmology alongside a full-time job.
TheMercury79
TL;DR Summary
Comparing sizes now and then
Imagine a Universe where the Hubble parameter is truly a constant, in both space and time.
How much smaller would such a Universe be 14 billion years ago compared to today?
Using the Hubble parameter in terms of scale factor: ##H(t) = \frac{\dot{a}}{a}## leads to
the differential equation: $$\frac{da}{dt}=a~H(t)$$
Solivng for the scale factor yields an exponential growth relation:$$a(t) = a(0)e^{Ht}$$
(##H(t) = H## since H is constant in this Universe and so it's not necessary to use the Hubble parameter
as a function of time)
If we use ##H = 70 kms^-1Mpc^-1##, current time ##t=14\times10^9~y## and initial time 14 Gy ago is ##t_0=0##, then$$\\$$
##Ht = 70~kms^{-1}~Mpc^{-1} * \frac{1}{3.09\times10^{19}}~Mpc~km^{-1} * (3600 * 24 *365.25 * 14\times10^9)~s##
This makes ##Ht## roughly equal to 1 and ##a(14)\approx a(0)e^1##
Therefore $$a(14)\approx 2.72a(0)$$
This, however, seems like a really small number, indicating the Universe was about one third of its current size
14 billion years ago for a "Constant Hubble Universe"
Also a value of 70 for the Hubble parameter corresponds to a Hubble time of 14 billion years. And if H(t) is constant then 14 billion years ago would have the same Hubble time of 14 billion years, it can't be one third of the current size and have the same Hubble time, shouldn't this Hubble time be zero 14 billion years ago?
Something(s) doesn't add upp in my approach and I'm trying to think of where I'm off
Space news on Phys.org
Well I think your beginning is wrong. You should derive the scale factor ##a(t)## from the Friedmann Equations. Not by using only $$H = \dot{a} / a$$.
From my knowledge, the only close thing that does look like your solution is universe with lambda only which has a scale factor of
$$a(t) = e^{H_0t}$$ however here $$H_0 = \sqrt{\frac{8 \pi G ε_Λ} {3c^2}} = \sqrt{Λ/3}$$
(Also called de Sitter universe)
Likes TheMercury79
##H = const## means that the universe is expanding exponentially. It's the case if the Cosmological Constant ##\Lambda > 0## and the matter density ##\rho = 0##, which is expected for the very far future of our universe.
Likes TheMercury79
I feel kinda stupid now, The Friedmann equations is in the next chapter. I was under the impression this should be solved with contents of the current chapter. But I see now I've read the curriculum wrong.
I have a full time job and taking this course on the side is really stressful. I just knew I was totally off on this.
Tnx for answers.EDIT: Actually I see now I haven't read the curriculum wrong. It's just not very clear, one place says this and that chapter, another place it says only this chapter. Huh
Likes Arman777
Abstract The Event Horizon Telescope (EHT) has significantly advanced our ability to study black holes, achieving unprecedented spatial resolution and revealing horizon-scale structures. Notably, these observations feature a distinctive dark shadow—primarily arising from faint jet emissions—surrounded by a bright photon ring. Anticipated upgrades of the EHT promise substantial improvements in dynamic range, enabling deeper exploration of low-background regions, particularly the inner shadow...
what is the current status of the field for quantum cosmology, are there any observations that support any theory of quantum cosmology? is it just cosmology during the Planck era or does it extend past the Planck era. what are the leading candidates into research into quantum cosmology and which physics departments research it? how much respect does loop quantum cosmology has compared to string cosmology with actual cosmologists?
