I HUP and the observer effect
  • I
  • Thread starter Thread starter DesertFox
    Hup Observer
DesertFox
TL;DR Summary
At the end of the day, aren't they the same?
The observer effect results from the interaction of a quantum system with a measurement device.
The HUP is more fundamental: it results from the fact that certain quantum measurements cannot be made simultaneously (or, equivalently: certain quantum observables do not commute, most famously - position and momentum).
The relevant wikipedia article says: "Historically, the uncertainty principle has been confused with a related effect in physics, called the observer effect, which notes that measurements of certain systems cannot be made without affecting the system, that is, without changing something in a system."
So, as far as I understand, the HUP is not observer effect. And that's held by the majority of scientists.
How do we know that they are different?Is there an experimental proof or it's all about math? Does the proof depend on the quantum interpretation which is applied?
Any explications of the topic will be appreciated!
Because the uncertainty principle is not a restriction on measurements or a property of measurements (although it is often misleadingly presented that way). It's a restriction on states. For example, the position-momentum uncertainty principle sets a limit on the possible states of a quantum system: there cannot be a state with position and momentum probability profiles that are more precise than the uncertainty principle allows.
Likes vanhees71, mattt and PeroK
Technically, IMO, the HUP is a statistical law derived mathematically from the theory of QM. It doesn't directly limit the precision with which (almost) simultaneous measurements of position and momentum may be made. That's not what it says, despite the common misconception to the contrary.
Experimentally, there are many ways you can try to outwit the HUP. Einstein and Bohr had a famous running debate on this where Einstein would come up with a thought experiment that seemingly outwitted the HUP; and Bohr would refute it.
In general, the HUP (and indeed the more general UP for other observables like spin) manifests itself in a specific way in each experimental set-up. This is where it is subtler than something like Newton's third law. You could invent an unlimited number of scenarios and ask how Newton's third law applies and the answer is similar in each case. Whereas, the limitations on nature's behaviour imposed by the UP are much subtler, deeper and varied. And, indeed, this can be seen as an essential foundation of the physical behaviour required to produce a complex universe.
In other words, without the UP, nature would be too simple to produce chemistry or anything interesting.
This post is a spin-off of the original post that discussed Barandes theory, A new realistic stochastic interpretation of Quantum Mechanics, for any details about the interpretation in general PLEASE look up for an answer there. Now I want this post to focus on this pre-print: J. A. Barandes, "New Prospects for a Causally Local Formulation of Quantum Theory", arXiv 2402.16935 (2024) My main concerns are that Barandes thinks this deflates the anti-classical Bell's theorem. In Barandes...
I understand that the world of interpretations of quantum mechanics is very complex, as experimental data hasn't completely falsified the main deterministic interpretations (such as Everett), vs non-deterministc ones, however, I read in online sources that Objective Collapse theories are being increasingly challenged. Does this mean that deterministic interpretations are more likely to be true? I always understood that the "collapse" or "measurement problem" was how we phrased the fact that...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In her YouTube video Bell’s Theorem Experiments on Entangled Photons, Dr. Fugate shows how polarization-entangled photons violate Bell’s inequality. In this Insight, I will use quantum information theory to explain why such entangled photon-polarization qubits violate the version of Bell’s inequality due to John Clauser, Michael Horne, Abner Shimony, and Richard Holt known as the...
