I am confused by the concept of space-time in special relativity
Space-time in special relativity combines three spatial dimensions with one time dimension, creating a unified framework known as Minkowski spacetime. In contrast, Newtonian physics operates with Galilean spacetime, where space and time are treated as separate entities, leading to less frequent references to the term "spacetime." The intertwining of space and time in special relativity reflects the effects of relative motion on measurements of time and distance. This distinction clarifies why "spacetime" is more commonly associated with Einstein's theories rather than Newton's. Understanding these differences is essential for grasping the implications of relativity.
rgtr
I am confused by the concept of space-time in special relativity, I have 3 spatial dimensions and 1 time dimensions. In Newtonian physics don't I also have 3 spatial dimensions and 1 time dimension? Then why call it space time in special relativity and not in Newtonian physics?
No equations
It is called spacetime in Newtonian physics too.
The difference is that Newtonian physics has Galilean spacetime where space and time are much less intertwined than in the Minkowski spacetime of special relativity or the general Lorentzian manifolds of general relativity. It istherefore much less common to talk about spacetime in Newtonian physics.
Thanks.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
