I need some help for the verification of an assignment about pendulums
Django is seeking assistance for a physics assignment on pendulums, specifically to verify his results with someone from a different country with varying gravitational force. He requests help in building a DIY pendulum using inexpensive materials and filming the process while making a sling. Django also asks for the period and length of the pendulum to be calculated using the formula provided, incorporating local gravitational acceleration. He emphasizes the need for the video to mention that it is made for him and his classmate Rens to avoid issues of plagiarism. The discussion highlights the importance of collaboration in educational assignments.
DvdP
Hello, my name is Django and I live in the Netherlands. I've got an assignment for physics about pendulums and part of this assignment is that I need to verify my result with someone else in a country with a different gravitational force (the gravitational force were I live is 9.813 N/m2). I wanted ask you whether you'd want to help me with this.
If you want to help you should build a DIY pendulum (with some cheap and easy to find materials) and film it while you make a sling.
After this I need you to fill in this formula:
T = the period in seconds (for the swing)
l = the length of the pendulum in meters (as you can see in the picture)
g = the acceleration due to gravity in m/s2
If you would help me with this I'd be very thankful!
Cheers,
Django van der Plas
PS.
Would you please say in the video that you make it for me and Rens, so I can prove that I haven't copied it from somewhere? Thanks!
Welcome to the PF. :smile:
Do you attend the same school as this student? https://www.physicsforums.com/threads/calculating-gravity.947845/
Yes, thank you, I couldn't find the thread! But nevertheless, I still need someone to help me as well, since I don't think our teacher will accept the exact same results :wink:
22K
