I try to solve a thermodynamics problem on heat transfer
The discussion focuses on solving a thermodynamics problem involving heat transfer between ice and water in a container. The exercise requires calculating the thermal capacity of the container, given that one-third of the ice melts when the system reaches equilibrium. The participant correctly identifies that the equilibrium temperature is 0 degrees Celsius and calculates the heat exchanged between the water and the ice. After performing the necessary calculations, they determine the thermal capacity of the container to be approximately 95,740 J/K, with a minor correction needed for one of the subtraction steps in their calculations. Overall, the reasoning and calculations presented are sound, confirming the approach taken in solving the problem.
Salmone
Thread moved from the technical forums to the schoolwork forums
Find the thermal capacity of a container with ice and water
##Q=C \Delta T##
I have some doubts about a thermodynamics exercise I did-I'll write down the text and show how I tried to solve it to see if I reasoned it out right.
In a container of thermal capacity ##C## containing ##1.0 kg## of ice at a temperature of ##-4.0 °C##, a mass of ##3.0 kg## of water is poured into it at a temperature of ##40.0 °C##. There is no heat exchange with the surroundings. The specific heats of water and ice are ##4186 J/kgK## and ##2090 J/kgK##, respectively, while the latent heat of fusion of ice is ##3.33 × 105 J/kg##.
The exercise asks to calculate the thermal capacity ##C## that the container must have if we want that at the equilibrium temperature just ##\frac{1}{3}## of the mass of the ice is melted.
I reasoned like this:
at the equilibrium temperature if the ice is not completely melted, it means the equilibrium temperature is 0 degrees. This means that the 3 kilograms of water will give up a total amount of heat equal to ##Q=cm \Delta T=(4186)(3)(40)=502320J##. This amount of heat will be absorbed initially by the ice to be brought to zero degrees and later to melt ##\frac{1}{3}## of the mass.
The heat absorbed by the ice for reach ##0## degrees can be calculated as: ##Q=cm(4 °C)=8360J##.
The heat absorbed by the ice in order to melt ##\frac{1}{3}## of the mass can be calculated with the ice latent heat of fusion as: ##\frac{3.33 x 10^5}{3}=111000J##
At this point, I can calculate the amount of total heat that the ice absorbs, which is the sum of ##8360J## and ##111000J## which is equal to ##119360J##, I can subtract it from the amount of total heat that the water gives up, and I get the amount of heat given up by the water that is not absorbed by the ice and must therefore be absorbed by the container. This quantity is ##502320J-119360J=382960J##.
I imagined that the initial temperature of the container was -4 degrees so this must absorb that amount of heat and have a heat capacity that allows it to raise its T by 4 degrees, absorbing that amount of heat.
From here I can calculate the final ##C=\frac{382960J}{4}=95740 J/K##
We are at the end of the problem, is this the right way of reasoning?
Please show more details of your equations and calculations. Your answer looks about right.
Your reasoning looks good to me. Your calculations also look correct except for this subtraction:
Salmone said:
##502320J-119360J=383785J##.
Thank you, corrected.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
