- #71
aawahab76
- 44
The following is the exact calculation but the gamma factor which is very small was deleted and because it is a multiplicarive factor in all numbers below, it will not affect any equality result if it is thereDaleSpam said:R' and R are two events which are lightlike separated, therefore they cannot occur at the same time. You are just experiencing some roundoff error and you probably have to use an arbitrary precision math package and look at the 10th decimal place to see the difference. I haven't checked your numbers, but I provided some numbers in a previous post which you can use to compare.
i) because O and P are spacelike separated, as we have already discussed
ii) it is a small difference in time, as I said several times already
iii) it does reduce to the Galilean transformation in the limit as c -> infinity
- R is (10^100/(3*10^8)=((10/3)*10^92 sec, 0) in F so in F' it is ((10/3)*10^92 sec,-10^91 m)
- R' is (1-(1/3)*10^82+(1/3)*10^92-(0.03/3)*10^(-8), 0')=((1-10^(-10))(1+(1/3)*10^92) sec,0') in F' but in F is given by ((1-10^(-10))(1+(1/3)*10^92) sec, 3*10^(-2)*(1-10^(-10))(1+(1/3)*10^92))
So what you said is true. However, for the moment, this is not related to our problem as I stated it in the list above but I think I can add to the list
14- As measured by the corresponding frame, P happened in very different times, but at approximately the same spatial location and received in approximately the same time by each observer. I am not yet intending any physical interpretation of this observation, if it is correct.
