I'm getting shocked Electricity grounding with 2-prong?
In summary: If you are playing with an amp that is not properly grounded, you may get small shocks. However, it shouldn't be anything big. Just be aware of the dangers and be careful. You also use this amp at your own risk.
  • #71
Yes, pretty bad.
I started to fix a radio like that once, without noticing it was transformerless "AC/DC". They were never common here.
I attached an aligator clip from a signal generator to the chassis and the tip of it it got turned to molten metal while I was holding it. There was a huge flash.
Fortunately, the signal generator was well grounded.
Never made that mistake again, but good grounding gave me the chance to learn from it.
That transformer amplifier has one capacitor, a 1960's paper capacitor probably, between you and sudden death. Even that stupid game Russian Roulette gives you a better chance of survival than that.
  • #72
sophiecentaur said:
You have not told us why the Neutral of the supply needs to be connected to anything other than one end of the secondary. Just refer to the one schematic that has been supplied to us and make your argument in terms of that.
And I hate to carp but could you please tell me what you mean by the word 'referenced'?
Neutral is not connected to the secondary, but to one end of the primary. That's the only connection neutral makes in the amp.
Re "referenced': Chassis ground is NOT necessarily mains (supply) ground. In a properly-wired amp with a working grounded power cord, plugged into a properly-polarized receptacle, it will be at mains ground, but there are many ways to sabotage that. In the simplest case, like a little Fender Champ, chassis ground can be referenced to Hot or to Neutral depending on which sockets the Hot and Neutral prongs are plugged into.
  • #73
I can't speak for him, but I think he meant primary, not secondary.
[/QUOTE]
Here we go again. If the Fender Champ you refer to is the same as the schematic posted in this thread (post #68) then you are WAY off. The only thing wrong with that schematic is that there is no 3rd wire ground hooked to the chassis of the amp. It is no different than using a 'cheater'. If that amp is left as the schematic shows it, it will never matter how the cord is plugged in as long as there is no accidental short from either of the wires in the cord. I am still waiting for a schematic of a guitar amp that shows the neutral conductor from the cord hooked to the chassis ground (which hooks to the sleeve of the input jack).
  • #74
Yeah, those paper capacitors are very unreliable. One of the first things you do when restoring an old radio (after replacing the power cord) is to replace all the electrolytic and paper capacitors. However, in the case of the Fender amp shown in schematic of post #68, my guess would be that the .047 mfd capacitor is a ceramic. Ceramics are very reliable. I don't think I've ever had one to fail. The value and voltage rating seem about right for a ceramic.
  • #75
I have tried to keep it simple and explain how polarity changes the potential of the chassis ground. Without much success, I might add.
Here is an illustrative schematic of the type of circuits Fender was using in the 60s and seventies. Just pay attention to the bottom of the schematic. See that switch labeled "ground switch"? Fender included that so that you could tie the chassis ground either to the hot or neutral leg. This type of wiring is illegal in much of the world, but it is still used in some high-end studio amps in the US. It does much the same thing as reversing the plug of an un-polarized power cord (both lugs the same size).
http://www.schematicheaven.com/fenderamps/super_reverb_ab568_schem.pdf
  • #76
That is called a floating ground. It was used on some of the old AC/DC tube type radios to help reduce the "hot-chassis" safety problem. The capacitor value is large enough to provide a path for audio but low enough to prevent electrocution. I did not know it was illegal.
Edit: The chassis is already a floating ground even without the capacitor.
  • #77
According to Dave Funk (manufacturer of Thunderfunk Bass Amps) it is illegal to include a switch to flip the ground reference from neutral to hot in European markets. His amps are quite high-end, so I'm pretty certain that he has explored the legal aspects.
  • #78
So I assume the reason for this is that the capacitor will allow enough current to pass to cause a shock? A .047 mfd capacitor connected directly to 120 volts at 60 hz will pass about 2ma. It takes about 10ma to kill.
  • #79
@Turbo:
I don't think that the 'ground switch' is 'referencing' anything when operating correctly. Notice the .047 uF 600 V cap is labeled UL. My guess is that it is a pretty bullet proof cap as caps go. Of course, nothing is failure proof. It looks to me like it accomplishes the same thing (more crude though) that the hum balance control does on the Marshall amp. I assume by 'reference' you mean that whatever is being referenced is at the same voltage as whatever it is being referenced to with the ability to source/sink current. Well that is where the difference is. A .047 uF cap has an Xc of about 56,500 ohms at 60 hertz. It won't pass any more current at 60 Hz than about 2 mA into a dead short.
I will say that it most certainly isn't perfectly safe and I wouldn't be surprised if it would trip a GFCI under some conditions. I'm not sure what the threshold is on the typical GFCI, I know it is pretty low, but I also know that it is common practice to use caps like that in modern present day equipment. Take a look at post #45 made by VK6KRO. The schematics in that have caps tied to ground the same way. If you look in Digi-Keys catalog you will find caps spec'd for just that purpose. With a 'cheater' adapter, you could probably make anything built today just as unsafe. At this point I am going to assume there aren't ANY guitar amps out there that use a power supply transformer that have the neutral tied DIRECTLY to signal ground. You haven't posted any schematic that shows it even though I've requested it several times.
Edit: Turtle, you posted a whole hour ago and I didn't see it??!??!??!??!?? :smile:
  • #80
Hot and Neutral are connected to the primaries of the power transformer. Using ground selector switch, it is possible to reference the chassis ground to either of them. In ungrounded amps you can accomplish the same thing by reversing the plug in the socket.
  • #81
Yes - for "secondary" read "primary" - me being sloppy. (sorry)
Are you actually reading the comments that we are all making?
Do you mean "connected to"? You still don't make it clear. You won't get a shock by a "reference" - you will only get a shock when there is a high enough Potential Difference between your finger and Earth.
If the chassis is not connected to ground, the Potential with respect to the Earth can be absolutely anything and is quite independent of the way round you plug the mains connector in. There is NO DC connection to the mains supply so there is no defined DC potential. The potential wrt Earth is only established once you choose to connect (any) part of the amplifier circuit to Earth. It is not and cannot be affected by the polarity of the mains connection. If you think that it is then perhaps you could give a coherent explanation - including something to do with Kirchoff's laws - which are the bottom line for any of these circuit problems.
  • #82
So far everything posted except the Marshall is ungrounded including the one with the switch. Maybe I'm confused by what you call grounded and ungrounded. Do you mean to say that an amp like the one in post #68 you can do what you call 'reference' to either the hot or neutral by reversing the plug? That's obvious. Aside from the switch, there is no difference. They are both what you call 'grounded' or 'ungrounded' or whatever.
  • #83
I've had that happen also. Not in this thread, but recently. Could be a bug.
Well, I think I have a good understanding of what the deal is with the capacitor and switch. I don't think it is as much of a safety hazard as turbo-1 has made it out to be. When properly selected, a capacitor can be as reliable and safe as a transformer. Yes, it could pass enough current to give you a shock. But not enough to be dangerous. And as Averagesupernova pointed out, the part is UL listed. If safety is a major concern then you could always just replace with a three prong plug and ground the chassis.
  • #84
Please wander over to a decent book-store and read Chapter 21 of Dave Funk's "Tube Amp Workbook" entitled "Ground Loops, Noise, and Safety". I can't copy his copyrighted materials and he gets into great detail about how you can get into some dangerous, perhaps fatal situations with guitar amps. Disregard the value of the capacitor in the ground-switch circuit. There are situations in which an improperly-configured guitar amp can nail you.
  • #85
Guitar amps - even valve amps are not a special, reserved, part of space / science. The normal laws governing how electricity works apply for guitar amps too. I would much rather look at a recognised publication about AC theory than a book about particular, niche, equipment - they can be a bit quirky at times.
Except for 'AC/DC' circuits, which should never have been allowed in the first place, the sense in which the primary of the mains transformer is connected has no bearing on the safety. It may have a bearing on the Hum, however, and it could be worth swapping - or swapping the secondary polarity, even. Reducing hum can be achieved as in the Marshall amp circuit in the earlier post, using a separate LV winding with a balancing pot to chassis. (Again, having no effect on safety).
I really wish you could explain (imagine you are talking to a complete idiot!) what you mean by "referenced". It really doesn't mean a thing to me, I'm afraid.
  • #86
Now that I understand the purpose and function of this capacitor I can relate to turbo-1's use of the word "reference". It may not be a good word to use, but I cannot think of a better one.
An effective way of reducing hum in an amplifier is to ground the chassis. Back in the 60's many U.S. households still had the old two prong unpolarized receptacles. One was the neutral and the other was the hot. The neutral was connected to ground at the transformer and/or service panel (so neutral was ground). The guitar amps of that era, had a floating ground chassis. Without a real ground, the amps would have a problem with hum. So a capacitor was installed between the chassis and the primary neutral/ground. The value of this capacitor was chosen so that it would provide enough of an AC path to ground to reduce the hum problem but not allow enough AC current to pass that would create a safety hazard (should it be connected to hot instead of neutral/ground). But since the power plugs of that day were not polarized, the user had to manually flip the plug to find the position that connected the capacitor to the neutral/ground (produced the least amount of hum). Or if the amp had a ground switch he could just flip the switch.
So when turbo used the word "reference" he was referring to the capacitor coupling between the chassis and neutral/ground or between the chassis and hot (depending on the plug or switch position).
Did I get that right turbo?
  • #87
I agree with your analysis of why they put the capacitor where they do. Isn't it usually described as 'coupling'? But where does the "referencing" come into it and where does it become a matter of 'safety'?
There is still no theoretical justification for those statements that turbo is making. The reactance of a 0.047uF capacitor at 50Hz is about j0.8MΩ. That won't let any more than a mild 'jolt' of current through you, even if your wet feet were planted on a copper floor at Earth potential. How can it be lethal?
I thought these fora were expected to vaguely scientifically rigorous so that the uninformed reader could rely a bit on what appears here. AC electricity not a mystical force and it obeys all the normal rules - so let's use them where we can.
Of course, we are relying on the integrity of those capacitors to provide isolation!
  • #88
That is the first thought that comes to mind of course. However, how many other single things are we relying on to provide isolation? Transformer windings, power switches, indicator lights, cord insulation, the list goes on and on. That is what engineering is all about. Making a determination of how important it is for a specific part to not fail and design/select that part or system around that criteria. There hasn't been any serious whining in this thread about those parts now has there? I think it has been recognized that there is a potential safety issue in that part of the circuit with that cap, but the recognizer has failed to see the numerous other potential safety issues within the amp and many other accepted systems that are no less serious than the cap.
  • #89
Agreed.
It's just a very good thing that AC/DC is no longer with us. My Dad scared me about that in the 60s and it has lived with me 'even unto today'.
  • #90
I am curious to see what the authors of the book recommended have to say. I don't feel like buying one, but I do have an interest in older technology and it just might be worth it.
  • #91
Just don't touch the chassis!
  • #92
Yes, that is correct. A chassis ground is NOT necessarily at the ground potential of the AC supply wiring. It can easily be at the same potential as the hot leg.
  • #93
Dave Funk's book is very popular among amp repairmen, and he addresses the many mistakes that Fender made over the years in their power supply configuration, including putting the fuse on the neutral leg, instead of before the power switch on the hot leg. Unfortunately, Marshall and other amp-makers often copied Fender's mistakes, so dangerous guitar amps are all over the place. If you're interested in older guitar amps, take a look at Dave's book. You will buy it - it's that good.
  • #94
Yes- it could be at the same potential but, with almost j1MΩ in series, how is it going to kill you - except if it causes you to fall off a ladder in surprise?
An isolated / insulated chassis could find itself at any potential - so can a human body.
  • #95
You might not be killed, but if you have ever had sweaty hands on the guitar strings and touch your wet lips to a grounded microphone, you might wish you had died. :biggrin:
  • #96
If the amp's chassis is at 120V (not neutral) and you're playing guitar, your strings and you will be at 120V, too. Touch a properly grounded mic, and your body becomes the path to ground. Musicians have died from this, so grounding/polarity is not trivial. It is likely that the OP was in a similar situation.
  • #97
Turbo, there is an important distinction that you have not made here. If musicians have died from the use of one of these amplifiers (that we have shown schematics for in this thread), it was not because of their design. It is more likely that a fatality would have been the result of a component failure. Or even more likely, someone who did not know what they were doing making internal modifications to it. If you disagree then tell me under what circumstances someone could be killed from one of these amps solely because of their design.
I'm not advocating that these amps are as safe as modern amps. They're not. But they are not going to kill you because of a design flaw. The improved safety standards of today's equipment simply means that your chances of personal injury is decreased when something goes wrong. If you drive a car without seat belts you are more likely to be killed if you are in an accident. But the lack of having seat belts does not cause the accident.
There's a Barns & Noble in a shopping center not far from my home. I will try to remember to check out that book you mentioned the next time I'm there. I'm not really into guitar amps but I am into old tube type equipment.
  • #98
No, the op was about a piece of equipment with a grounded three prong plug where the ground prong had fell off. Actually, I find it very unlikely that the prong would just fall off. It's more likely that someone cut it off. I've seen people do that when they want to use a two wire extension cord with a three wire grounded device. They're in a hurry and don't have time to go out and purchase the proper cord. Anyway, the point is that the op situation is not a case of improperly designed equipment. It's a case of improper and dangerous user modification. The simple solution is to replace the plug, which someone had already suggested.
  • #99
I make that reactance about 67.76 K and the current from 250 volts would be 3.7 mA rms, neglecting body resistance.
So, you would feel it, but it might not kill you.
But, that is talking about a relatively safe amplifier as long as no components in the primary of the transformer fail. The bad ones are where they connect one side of the mains to the chassis and attach a reversible plug to the power cord.
Incidentally, the original poster of this thread was last seen on April 27th. We all agree that it is bad to electrocute people and we can't correct the bad mistakes of the past, so maybe it is time to wind this one up?
  • #100
There are many older Fender amps (and others) that could easily end up with 120V Hot on the chassis through improper modification, internal failure, etc. When a guitarist using such an amp touches another instrument or a mic that is properly grounded, their body becomes the easiest path from hot to ground. Mouth to hand, hand to hand... both can put the heart in the path and it doesn't take much to stop a heart.
  • #101
Probably a good idea. I made it a campaign of mine to make every amp that I serviced as safe as possible, and took offense to people who minimized the risk of shock, and that seems to have ticked off a few people. Like Dave Funk, I have dissected amp designs and have refused to service amps if the owners did not let me modify them to current safety standards (fuse on the hot leg before the power switch, 3-prong plug securely grounded to chassis, etc, and NO "ground switch" allowing the chassis to be referenced to either hot or neutral). I was a small operator, but was not about to allow people to be put at risk because I ignored the mistakes of the amp designers. I highlighted Fender stuff (and Marshall) because that was the bulk of my business, but you could find some pretty "interesting" configurations in Gibson, Gretsch, and Supro amps, too, that were worse than Fender's missteps. Get into some of those amps, that are true point-to-point amps (no tag-board or circuit-board) and you've got to learn to "read" the circuit without a map.
  • #102
I wouldn't kill this yet quite simply because it is not resolved. I figured 120 volts and not 250. Not sure if any of those came in a 250 volt option. I also cannot imagine ANY guitar amp design with a true hot-chassis (no power transformer). So let's throw that one out of the discussion. I am going to try to have a look at the book and post based on my findings.
  • #103
Turbo, I did not take offense. I was just confused by some of your statements. You made it seem as if the chassis was hot under some circumstances because of a design flaw. You also mentioned something about the DC voltages of two amps causing a problem - which I still don't understand. But I'll let it go if every one wants to end the thread.
By the way, if I were servicing amps I would do the same as you. I would want to bring them up to modern safety standards. It's a really simple matter to remove the capacitor and ground the chassis with a three wire power cord. So there's no conflict there either.
  • #104
Nor did I. Amp-techs who deal with vintage amps have to talk about ground (chassis ground and string/player ground) knowing that user-actions, mods, and component failures can conspire to put that ground at any potential from neutral to hot and anyplace in between.
BTW, Leo Fender and his crew "made do" and they did some stuff that would never have been allowed today. Back then, the progression from non-polarized power supplies to polarized power supplies to polarized and grounded power supplies was VERY slow. The conversion of music venues often lagged by decades, and Fender did nothing to keep up with the modernization until they had to, because musicians would have been "inconvenienced" by the more stringent safety standards and might not have bought new Fender amps because of it.
  • #105
I thought this was interesting: http://www.highvoltageconnection.com/articles/ElectricShockQuestions.htm
Also, I tested a GFCI tonight with a 47K resistor. Not enough to trip. Should have passed about 2.5 mA. Allen Mottershead second edition Electricity and Electronics claims it takes about 5 mA to trip a GFCI. Notice that is the same current as stated in the table as maximum allowable safe current. I didn't test the GFCI with a 5 mA load since I don't have a resistor rated at enough wattage. All of the ones I have on hand would smoke. Please don't take this post as saying that 'if it won't trip a GFCI then it must be perfectly safe'.
