Impulse and momentum question, relates to Biomechanics
In the discussion, participants analyze the biomechanics of a male dancer lifting a female dancer, focusing on calculating her vertical velocity upon release. The initial calculation of change in velocity was incorrect because it did not account for gravitational force (g). The correct approach involves recognizing that both the upward force exerted by the male and the downward gravitational force must be considered to find the net force acting on the female dancer. By incorporating gravity, the accurate vertical velocity when she is released is determined to be 2.69 m/s upwards. Understanding the net force is crucial for solving similar problems in biomechanics.
urbano
A male and female pair of dancers start dancing when the male lifts the female and throws her into the air. The female's mass is 40kg . The male exerts an average vertical force of 500n for 1.0s on the female.
What is her vertical velocity when she is released into the air ?
I chose to go with Force x Change in time = Mass x Change in Velocity
FΔt = mΔv
So I initially came up with
500N x 1.0s = 40kg x Change in velocity
(500N x 1.0s)/ 40kg = Change in Velocity
Change in velocity = 12.5
The correct answer (if 9.81 m/s is used for g) is 2.69 m/s upwards. I hadn't accounted for g in my answer and am not sure how to incorporate it.
Is the force that the man exerts on her the only force acting on her?
to the best of my knowledge yes, I have literally written out the question as it was presented.
Don't forget gravity. (That's where g comes in.)
yes this is where I'm confused...how do you incorporate g into it ?
There are two forces acting on the woman: The upward push from the man and the downward pull of gravity (her weight). You need to use the net force to calculate her change in velocity.
  • · Replies 24 ·
