- #36
- 23,377
- 5,733
And you actually accepted this?gracy said:I have gone through this site
http://www.answers.com/Q/What_happens_when_the_equilibrium_constant_is_zero_for_a_reaction
Chet
As Bystander and I have both said, the equilibrium constant can't be zero.gracy said:No.I was confused that's why asked here.
Yes.I can surely trust you.Now i will no longer be confused about this.Chestermiller said:As Bystander and I have both said, the equilibrium constant can't be zero.
Can you please explain why gibb's free energy becomes zero when k i.e equilibrium constant is 1.I know this comes from the formula G=-RT ln K but i want to understand the concept behind this.Why system has no available energy to do work if it's reactants and products have same concentration?Bystander said:It's never zero. You might have seen "lnKeq = 0" which means the equilibrium constant = 1, but K itself can never equal zero; that condition gives you an infinite negative free energy for whatever reaction is represented by "K" and that reaction proceeds some infinitesimal amount to reduce the magnitude of that negative free energy.
You seem to be ascribing some special significance to the situation where the equilibrium constant is unity. This value of K is no more special than any other value of K. Remember also that the standard free energy change refers to the change in free energy starting out with the pure reactants in stoichiometric proportions at 1 atm., and ending up with the pure products in corresponding proportions at 1 atm. In the equilibrium constant K, you are talking about the reactants and products not necessarily in stoichiometric proportions nor at 1 atm pressure, and the partial pressures of the reactants and products even don't have to be equal; in fact, even, if there are only single moles involved, the only requirement is that the product of the reactant partial pressures must match the product of the partial pressures of the products. If the final number of moles is different from the initial number of moles, not even this is required.gracy said:Can you please explain why gibb's free energy becomes zero when k i.e equilibrium constant is 1.I know this comes from the formula G=-RT ln K but i want to understand the concept behind this.Why system has no available energy to do work if it's reactants and products have same concentration?
So ,you mean at equilibrium ΔG =0 but ΔGo is not zero instead ΔGo = -RT ln(K).Right?Ygggdrasil said:ΔG = 0 and Q = Keq, so rearrangement of equation 1 gives the relationship everyone learns in gen chem: ΔGo = -RT ln(K)
Backwards. If the product has a larger free energy (in the arithmetic sense, more positive) it means it's necessary to put energy/work into the reaction to form the products.gracy said:delta G is positive ,i.e product has larger free energy than reactant.It means product has greater tendency to do work than product,right?
How does it imply that product will have larger tendency to do work?Is it like thisBystander said:If the product has a larger free energy (in the arithmetic sense, more positive) it means it's necessary to put energy/work into the reaction to form the products.
Yes. You have "pushed" the "chemistry" up the energy hill, and stored energy that can be released.gracy said:Is it like this
Correct.gracy said:at equilibrium ΔG =0 but ΔGo is not zero instead ΔGo = -RT ln(K).Right?
I left this for Yggg to handle since it was in response to something he posted, but it's been long enough ----.gracy said:So in this video
At time 1:13 is he wrong?
Use "ΔG" when looking at a system for which reactants and products are NOT in their standard states. Use ΔG0 and the activity relation when you are trying to find ΔG.gracy said:Where should I use ΔG and where should I use ΔG0?
This is the general expression for change in Gibb's free energy. It's always valid.gracy said:ΔG = ΔH - TΔS Is this right?
ΔG = - nFE gives you the emf of an actual cell, and ΔG0 = - nFE0 gives the emf of a cell in which reactants and products are in their standard states.gracy said:ΔG =nFE or ΔG0=nFE?
Van't Hoff Equilibrium Box is a kind of vessel which has constant volume and the various substance which take part in any reaction are in equilibrium.The wall of this vessel is permeable to only some substances.This box is only applicable for homogeneous systems.Chestermiller said:Are you familiar with the Van't Hoff Equilibrium Box?
This is kind of correct, but let's make it more precise. Is there only one semipermeable membrane? What about the temperature?gracy said:Van't Hoff Equilibrium Box is a kind of vessel which has constant volume and the various substance which take part in any reaction are in equilibrium.The wall of this vessel is permeable to only some substances.This box is only applicable for homogeneous systems.
I think it depends on number of walls of van't hoff box.Chestermiller said:Is there only one semipermeable membrane?
At constant temperature.I guess.Chestermiller said:What about the temperature?
I don't know about this.Please help me.Chestermiller said:We've been talking about ΔG and ΔG0. If you had a Van't Hoff Equilibrium Box available to you, how would use use it to experimentally measure ΔG0 for a reaction involving ideal gases? (Use of supplementary equipment, such as cylinders with pistons, is allowed.)
gracy said:I think it depends on number of walls of van't hoff box.
So,how many?Chestermiller said:No. The is a separate semipermeable membrane for each reactant and each product of the reaction.
As I said, one membrane for each reactant and one membrane for each product. Does every reaction have the same number of products and reactants?gracy said:So,how many?
It would really help with your understanding if you could describe how a Van't Hoff equilibrium box could, at least conceptually, be used to determine ΔG0 for a reaction. Rather than my trying to go into the details of this, I'm hoping you will consider reading up about this in your Thermodynamics book or online. I will be glad to answer any questions. FYI, ΔG0 refers to the difference in Gibbs free energy between the following two thermodynamic equilibrium states:gracy said:I don't know about this.Please help me.
He's being very loose with the terminology and mixing up the standard change in Gibbs free energy and the real change in Gibbs free energy.gracy said:So ,you mean at equilibrium ΔG =0 but ΔGo is not zero instead ΔGo = -RT ln(K).Right?
gracy said:Where should I use ΔG and where should I use ΔG0?I mean the formula
ΔG = ΔH - TΔS Is this right?or it is only applicable for standard gibbs free energy ..
That appears to be the way "galvanic" is interpreted/defined/used. I don't remember the distinction being quite so absolute fifty years ago, but life is lots easier if we bow to current convention and use.gracy said:in galvanic cell reactions are always spontaneous
As a consequence of the current definition, that is correct.gracy said:negative EMF is not possible
"Potential/voltage input" is some voltage source external to the electrolytic cell of interest, like a battery charger.gracy said:The potential/voltage input + the cell potential must be > 0 for the reactions to occur.
What is potential/voltage input ,and the cell potential ?How these two differ?
