Inclined plane and elapsed time
The discussion revolves around solving a physics problem involving a block moving up a 20° inclined plane with an initial speed of 5.0 m/s. Participants analyze the equations of motion, particularly focusing on the correct application of acceleration due to gravity along the incline. There are errors identified in the calculations, particularly in determining the time and distance traveled by the block. Clarifications are made regarding the signs of acceleration and the need to account for the incline's angle correctly. The conversation emphasizes the importance of re-evaluating calculations to arrive at accurate results.
Sassenav22
A block is given a initial speed of 5.0 m/s up the 20° plane. (a) How far up the plane will it go?
(b) how much much time elapses before it returns to its starting point?
I think
V= u + at
s=ut t 1/2at^2
v=d/t
(a) V= u + at
0= 5-9.8(sin20)t
t = 1.65s
s=ut+1/2at^2
=5(sin20)(1.65)+ 1/2(9.8)(1.65^2)
s= 16.16m
(b) v=d/t
t=d/v
=16.16/5
t= 3.2s
I know this is wrong but i can't figure it out can someone help me?
Sassenav22 said:
V= u + at
0= 5-9.8(sin20)t
t = 1.65s
Recheck your arithmetic. (Tip: Once you've solved for the time the block takes to rise, what's the answer to part b?)
s=ut+1/2at^2
s= 16.16m
The initial speed up the ramp is already parallel to the incline, so there's no need to multiply it by sin20. On the other hand, the acceleration along the incline is only a component of g, so you do need the sin20 there. Also, should the acceleration be + or -?
acceleration should be positive
So what your saying is that the sin20 is suppose to beby the 9.8?
No. The ramp slopes up, so acceleration is negative (down).
Yes, the acceleration of the block is g sin20.
Oh, Is the first part of (a) correct because I found the time so that i could find the distance, is that what is suppose to be done?
Yes, that's a perfectly fine way to solve the problem. You just made an error when you did the final arithmetic to solve for the time.
so its:
(a) V=u+at
0=5+9.8(sin20)t
t = 1.65s
s= ut+1/2at^2
= 5(1.65)+1/2(-9.8)(sin20)(1.65^2)
=3.69m
(b) v=d/t
5=3.69t
t=3.39/5
t=0.68s
Sassenav22 said:
(a) V=u+at
0=5+9.8(sin20)t
t = 1.65s
The final answer is still wrong. Redo the calculation.
s= ut+1/2at^2
=3.69m
You'll need to redo this with the correct time.
(b) v=d/t
5=3.69t
t=3.39/5
t=0.68s
No. Read my "tip" in post #2.
v=u+at
= 5-9.8(sin20)t
t= 1.64s
I still get the same answer
Sassenav22 said:
v=u+at
= 5-9.8(sin20)t
t= 1.64s
I'm curious how. t = 5/(9.8sin20) = ??
  • · Replies 16 ·
  • · Replies 18 ·
