Inclined Plane Problem Two Parts
The discussion revolves around solving an inclined plane physics problem involving a block sliding down a frictionless surface at an angle of 24.5°. The initial calculation for acceleration was incorrectly derived, leading to confusion about the application of Newton's second law. The correct approach involves resolving the gravitational force into components parallel and perpendicular to the incline. The final speed of the block at the bottom of the incline was calculated using the incorrect acceleration, prompting a need to reassess the force components. Understanding how to properly calculate these components is crucial for solving the problem accurately.
sugarntwiligh
The block shown in Fig. 4-48 lies on a smooth plane tilted at an angle θ = 24.5° to the horizontal. Ignore friction.
http://www.webassign.net/giancoli5/4_48.gif (visit this site for picture)
(a) Determine the acceleration of the block as it slides down the plane.
(b) If the block starts from rest 9.50 m up the plane from its base, what will be the block's speed when it reaches the bottom of the incline?
a.)
9.8/sin(24.5)=23.6 m/s^2 which is the acceleration down the slope where the x=ma and the y=mg. Is this correct? It feels like I am forgetting something...
b.)
From the equation v^2=vi^2+2ad,
v^2=0+2*23.6*9.5
v=21.2m/s at the bottom of the incline.
sugarntwiligh said:
a.)
No, it's not. What forces act in the x direction? Apply Newton's 2nd law. (Sanity check: Compare your calculated acceleration with g. Does your answer make sense?)
b.)
v^2=0+2*23.6*9.5
If you had the correct acceleration, that approach would work.
I didn't use any value of x in my equation. But I am still confused about why its wrong, because sin(24.5)=(9.8m)/(ma). Where mg is the opposite and ma is the hypotenuse. And then solving for a gives me the same answer.
My answer would make more sense if I did 9.8sin(24.5)=4.06, and I think this is the right way to go, but why?
To use a triangle to find force components, you must realize that the total force is "mg", so mg must be the hypotenuse of your right triangle. (That right triangle is not simply the incline.)
You need to learn how to find the components of the weight parallel and perpendicular to the incline surface. Read this: http://www.glenbrook.k12.il.us/gbssci/Phys/Class/vectors/u3l3e.html"
Ohhhhhhhhh I get it! Thanks!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
