Index of Refraction Homework: Investigating Snell's Law
The discussion revolves around verifying Snell's Law of Refraction by measuring the index of refraction for water using a half-circle setup. The procedure involved measuring an incident ray at a 30-degree angle from the normal line and aligning pins on the curved side. A key question raised is why refraction was not observed on the curved side. It is suggested that any line drawn to the curved side acts as a normal line, implying no refraction occurs. The inquiry highlights the relationship between the angle of incidence and the geometry of the setup.
uchicago2012
In a lab we did, we verified Snell's Law of Refraction by measuring the index of refraction for water. We filled a plastic half-circle with water and drew a line normal to the flat side. We measured an angle 30 degrees from the normal line (called the incident ray). We then looked at a pin on this incident ray through the water and aligned pins with it on the curved side. I attached our procedure in case none of that makes sense. But I was wondering why we didn't do refraction on the curved side?
Snell's Law: n1sin(θ1) = n2sin(θ2)
3. The attempt at the solution
I thought it might be because any line we draw to the curved side would be a normal line and thus there would be no refraction?
Any ray that originates in at the center of the flat side that passes through the water and exits the curved side is following a radius of the arc. What does that tell you about the angle of incidence of the ray with the curved side (from the water side)?
