Induced charge on a conducting sphere sliced by a plane
The discussion revolves around a conducting sphere that is sliced by a plane, creating two unequal parts, with a charge Q given to the smaller section. Participants explore the application of Gauss's law to determine the induced charges on the curved and flat surfaces of the larger hemisphere and the interaction force between the two sections. It is confirmed that the electric field is radial just outside the curved surfaces, but there is also an electric field present in the gap between the flat surfaces. The assumption that the potential throughout the sphere remains constant due to the negligible gap is accepted, but the charge on the flat surfaces must be considered when calculating the net force between the two parts. The conversation concludes with a request for the specific amounts of charge on the surfaces, expressed in terms of Q and r.
Hellec408
Thread moved from the technical forums to the schoolwork forums
We are given a conducting solid sphere, and it is cut by a plane which has a minimum height r/2 from the centre of the sphere, which has radius r.
A charge Q is given to the smaller part of the conductor, and it is required to find the induced charge on the curved and flat surfaces of the other hemisphere, and also the force of interaction between the two parts of the sphere.
My initial approach was to apply Gauss law, as we know that electric field is always perpendicular to the conductor surface, and hence we can claim that field in both parts is radial and that the induced charges on the facing flat faces are equal and opposite. Then I assumed that since the gap between the faces was negligible, the potential throughout the sphere is constant, and thus the system is equal to a conducting sphere having a charge Q distributed evenly over it.
Am I correct in assuming thus?
How can the force of interaction be found in that case?
I think this is saying that the perpendicular distance from the center of the sphere to the plane is r/2. Is that correct?
The plane divides the sphere into two unequal-sized pieces. Neither piece is a hemisphere. (I probably sound too nit-picky, but I want to make sure that I'm interpreting the problem statement correctly.)
Yes, the field is radial just outside the curved surface of either piece. But there is also an electric field in the gap between the two flat surfaces. This field is not radial.
Yes.
Yes. In crossing the electric field in the gap, the change in potential will be negligible since the distance between the surfaces is infinitesimal.
Yes, this is correct for the charge on the outer surfaces of the two pieces. But, you cannot neglect the charge on the flat surfaces when finding the net force on one of the pieces. The oppositely charged flat surfaces attract each other.
Have you found the amount of charge on the curved and flat surfaces of the larger piece? These can be expressed in terms of Q and r.
Thanks, got it!
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
