Inertial vs Gravitational Mass "mystery"?
The discussion centers on the mystery of why gravitational mass is proportional to inertial mass, a foundational aspect of classical mechanics that lacks a clear explanation. Participants explore the operational distinctions between the two types of mass and question why they are treated as separate despite both being measured in kilograms. The equivalence principle in general relativity is highlighted as a potential resolution, indicating that all objects fall identically in a gravitational field due to following geodesics in curved spacetime. The conversation also touches on the implications of this principle for understanding gravity and its relationship with other forces, particularly electromagnetism. Ultimately, the discussion underscores the ongoing mystery in physics regarding the fundamental nature of mass and gravity.
  • #61
atyy said:
I think the problem is that Dr Stupid is taking "inertial mass=gravitational mass" to be exact. It is exact in Newtonian gravity.
Exactly. I have no problems with the Galilean equivalence principle. It is the Newtonian equivalence principle that confuses me in the context of GR. I assume it simply makes no sense in GR but i am not completely sure of that.
  • #62
jtbell said:
I think E&M and gravity would have to be described by two different kinds of spacetime. I suppose you could call them "parallel" spacetimes, but that might have too many science-fiction connotations. :eek:
As long as there ends up being a link from one to the other, so we can find a way to control one through the other (I really want flying cars already!)
  • #63
DrStupid said:
The quoted text doesn't even mention inertial or gravitational mass. Please be so kind to answer the question.
I did. I explained why all objects (with a negligible mass) move on trajectories independent of their composition. This is equivalent to the equality of inertial and gravitational mass.
The paper results in a factor of 1+v²/c² between inertial and gravitational mass.
It does not calculate the gravitational mass of the passing object at all. It calculates the deflection an object sees in a specific setup and looks "if this would be an object with Newtonian gravity [WHICH IT IS NOT!], what would be its mass".
DrStupid said:
The abstract doesn't looks like it is about inertial and gravitational mass and I don't want to sign in for the full paper because proving your claims is not my responsibility.
Helping you to understand papers is not my responsibility.
DrStupid said:
And what does GR say about inertial and gravitational mass?
That they are identical, as mentioned multiple times.
  • #64
What's the difference between the Galilean equivalence principle and the Newtonian equivalence principle?
  • #65
However, in GR, inertial mass is not a fundamental quantity, and neither is gravitational mass. One could ask, if a mass follows a geodesic exactly, even if one includes backreaction of its mass on the background. If the backreaction is not included, then its mass is not gravitational.
Usually to avoid this problem, the weak EP is not formulated as "inertial mass=gravitational mass", but closer to what Dr Stupid is referring to as the Galilean equivalence principle. For example, http://relativity.livingreviews.org/Articles/lrr-2006-3/ section 2.1.
Also even if one uses universality of free fall, I think it is only true to some approximation in GR (due to backreaction problems). That's fine, since the EP is only local. However, if one states the EP as minimal coupling, then it is exact in GR.
Universality of free fall is technically untrue in Newtonian gravity as well, this is not a problem unique to GR. A larger mass attracts the Earth more than a smaller mass, and will fall ever so slightly faster to Earth due to this effect. Consider a Jupiter sized mass "falling to Earth". Only in the limit where the second mass can be ignored w.r.t. the Earth's mass can the strict adherence to any Equivalence principle be followed. But this is not a problem of the equivalence principle, it is an additional complication that we should be mindful about. Similarly, that objects follow geodesics in GR is only approximately true for small objects in a background (much larger) gravitational field. The real equation of motion in GR derives from the condition ##\nabla T=0##, the local conservation of stress-energy. The two body problem is not solved analytically in general relativity like it is solved in Newtonian mechanics which gives us more complications.
I don't see any of this as being a problem for the weak equivalence principle; however, because practically speaking, the objects we drop in our experiments ARE negligible in mass (20-24 orders of magnitude smaller) as compared to the Earth.
  • #66
But is WEP the universality of free fall, or is it "inertial mass = gravitational mass". If it is the latter, how are inertial mass and gravitational mass defined in GR?
  • #67
I think I have made my position on this matter quite clear in my earlier posts. I do not wish to continue that argument, you can refer to my previous posts to see what I think about this issue.
  • #68
Which specific posts?
  • #69
See posts #35,37,41,44
  • #70
If you define inertial mass and gravitational mass via the Eotvos experiment, are you assuming the Newtonian limit of GR?
  • #71
Are you saying you expect the Eotvos results to perhaps not hold up if the experiment were conducted near a black hole?
I don't think that we are assuming a Newtonian limit of GR. That experimental physics can make a clear, unambiguous, and concise measurement of the validity of the weak equivalence principle, or "inertial mass = gravitational mass", I think it also provides us a clear, unambiguous definition of the statement "inertial mass = gravitational mass" no matter which theoretical framework you want to work with.
GR takes this principle, and others (incl. principle of relativity, etc.), and makes several conclusions based on them. That the WEP is embedded in the statement "all objects free-fall along geodesics" is clear I think. When you test the WEP, you are certainly testing GR as well, for if it fails, then GR has failed as well.
  • #72
No I am not suggesting that anything about the Eotvos experiment results. I would like to understand why you say the Eotvos experiment tests "inertial mass = gravitational mass". In GR, without the Newtonian limit, inertial mass and gravitational mass are not defined. In Newtonian gravity, inertial mass and gravitational mass are well defined. So I can understand that we have the Eotvos experiment, and the Eotvos experiment tests the equality of inertial and gravitational mass within Newtonian gravity. We can also have the Eotvos experiment be a test of GR. But given that without a Newtonian limit, inertial and gravitational mass are not defined in GR, how can the Eotvos experiment test the equality of inertial and gravitational mass in GR?
  • #73
As I have said, and reiterated, several times now, in GR the statement "inertial mass = gravitational mass" is embedded in the statement "all things free-fall along geodesics". Because GR took "inertial mass = gravitational mass" as its foundational principle, the WEP is automatically satisfied in GR. As I said before, if you don't want to say "inertial mass = gravitational mass", then fine, you can just replace it with the "Weak Equivalence Principle", but I think you will simply be confusing more people than you are helping.
A physical test, a physical experiment, like the Eotvos experiment is CONDUCTED and does NOT require ANY theoretical model to back it up. Such that the phenomena are observed is independent of any THEORY. As such, one can take the concepts tested for in the Eotvos experiments as the experimental foundation for the weak equivalence principle, the statement that I, and many others, prefer to call "inertial mass = gravitational mass". If you have objection to the terminology, then you are free to refer to it as something else as long as people will still be able to understand what you are saying.
  • #74
What do you mean "embedded" and "founding principle"? Which quantity in GR is inertial mass? Which quantity in GR is gravitational mass?
This conception backs up the idea that you don't mean anything specific by "inertial mass = gravitational mass", since you are just saying this method doesn't require any theoretical concepts. Unless inertial mass and gravitational mass are such self-evident concepts that they are not theoretical, within this conception inertial mass and gravitational mass seem to be meaningless terms since they are theoretical.
  • #75
Here is an interesting comment in a paper by Di Casola, Liberati and Sonego that seems to agree with you. If I understand them correctly, inertial mass and gravitational mass are defined in GR in the Newtonian limit of GR.
http://arxiv.org/abs/1401.0030
http://journals.aps.org/prd/abstract/10.1103/PhysRevD.89.084053
"Newton’s Equivalence Principle (NEP). In the Newtonian limit, the inertial and gravitational masses of a particle are equal. This formulation makes it possible to test NEP also for theories other than Newton’s. What really matters, in fact, is the notion of Newtonian limit, for the identification of an inertial and a gravitational mass is in general unambiguous only in those conditions."
  • #76
That's a common misconception. It's been discussed here at PF before. The UFF will hold true regardless of the mass difference between the two bodies in the two body problem. The misconception is caused by a confusion between the relative acceleration and the acceleration of each body relative to their common center of mass (barycenter). When you change the mass of either body, you also change the relative location of the barycenter. For example, if you increase the mass of a falling body, the barycenter moves closer to the falling body by just the right amount to keep it's acceleration (relative to the barycenter) the same.
It is the acceleration of each body relative to the barycenter that applies to the UFF, not the acceleration of one body to the other.
  • #77
Fair enough. Since I have not studied closely the full 2-body problem in GR (which I am told has no analytic solution), I will stick to the approximation where one body has negligible mass.
  • #78
You do not agree that Einstein founded his theory of general relativity starting with the weak equivalence principle?
Did I not say like 5 times before that if you don't want to say "inertial mass = gravitational mass "you can replace it with "the weak equivalence principle"? Are you saying "the weak equivalence principle" holds no theoretical ground in GR?
  • #79
Sure, if you would like to talk history, not physics. He also used the principle of general covariance.
What is the weak equivalence principle?
  • #80
By this you are implying that general relativity does not obey the weak equivalence principle?
I like this statement: The trajectory of a point mass in a gravitational field depends only on its initial position and velocity, and is independent of its composition and structure.
Taken from wikipedia: http://en.wikipedia.org/wiki/Equivalence_principle#The_weak_equivalence_principle
  • #81
It depends on what you mean by weak equivalence principle. For example, I don't know whether you mean "inertial mass = gravitational mass" or some form of universality of free fall.
OK, that's basically universality of free fall. As far as I can tell Dr Stupid has no problems with this, which is basically near geodesic motion of a small body in GR. He is only asking whether "inertial mass = gravitational" mass has any meaning in GR. As far as I can tell, it does not have meaning in GR unless one takes the Newtonian approximation, which corresponds to the basic idea that "inertial mass" and "gravitational mass" are Newtonian concepts. However, what was confusing is that you did not agree that the Newtonian limit was necessary for these ideas to make sense in GR.
So if you don't defend "inertial mass = gravitational mass" as a GR concept even without a Newtonian limit, I believe you are agreeing with Dr Stupid.
I think he would say that WEP is UFF (exact, or very good approximation). And that Newtonian gravity uses the technical concept "inertial mass = gravitational mass" to enforce WEP. On the other hand GR uses the technical concept of "minimal coupling in the action" to enforce WEP. Since GR has Newtonian gravity as an approximation, then in that regime GR also has the concept of "inertial mass=gravitational mass".
  • #82
Not really:
http://en.wikipedia.org/wiki/Theory-ladenness
  • #83
atyy said:
OK, that's basically universality of free fall. As far as I can tell Dr Stupid has no problems with this, which is basically near geodesic motion of a small body in GR. He is only asking whether "inertial mass = gravitational" mass has any meaning in GR. As far as I can tell, it does not have meaning in GR unless one takes the Newtonian approximation, which corresponds to the basic idea that "inertial mass and "gravitational mass" are Newtonian concepts. However, what was confusing is that you did not agree that the Newtonian limit was necessary for these ideas to make sense in GR.
Fine. I think my post in #41 was quite clear, and did not make any statements contrary to the statements you made here. I do not think this discussion should have taken this long, and I no longer think this discussion has any fruit to bear. If it was ambiguities in my language at fault, I apologize to Dr. Stupid.
  • #84
madness said:
A discussion of this will bring us far afield and into the philosophy of science, I fear. If you are not comfortable with my statement in that post with regards to a SPECIFIC physical consequence, then please bring it up. If you are just nit-picking my words because a deep discussion of the philosophy of science means that any scientific thought will likely be based on past paradigms and human philosophical assumptions, then I have no interest in discussing that.
My language is not perfect. I am not perfect. I am human, and am prone to make small lapses in coherence of argument. Are we good here?
  • #85
Well I don't agree with the nit-picking etc., but I agree not to go into philosophy, so yeah...
  • #86
Basically, I agree with you to avoid mind-bending intricate discussions of the EP, but I just thought Dr Stupid had a point here, since some standard texts and even quite recent papers like the Di Casola paper I linked to do discuss these things. For example, IIRC MTW has a "medium-strength" EP, which I cannot remember what it is anymore, if I ever understood what the distinction was. I'd personally just go with spin 2 and *derive* the EP (ok, I don't actually know what that means, but apparently it can be done). :)
  • #87
I've been doing a little research this evening and to the best of my ability it seems that all of the principles we have been discussing (weak equivalence principle, Galilean equivalence principle, and the Newtonian equivalence principle) include the concept of "passive gravitational mass = inertial mass"; possibly the most tested concept in physics.
Personally, I don't see what the "mystery" is. To me the equivalence of active gravitational mass and inertial mass is where the mystery lies. From Wolfgang Rindler's book "Relativity: Special, General, and Cosmological: "the equality of inertial and active gravitational mass [...] remains as puzzling as ever".
Likes atyy
  • #88
Within GR, this fact is put in by hand as universal and minimal coupling between spacetime and matter in the action. Then the mystery becomes: why this universal and minimal coupling? Surprisingly, there is a claimed derivation of this form of the equivalence principle by considering gravity to arise from quantum spin 2. See http://arxiv.org/abs/1007.0435, section 2.2 "The Weinberg low-energy theorem", especially section 2.2.2 "Equivalence principle: the spin-two case".
  • #89
Galilean equivalence principle: The trajectory of a point mass in a gravitational field depends only on its initial position and velocity, and is independent of its composition and structure.
Newtonian equivalence principle: inertial mass = gravitational mass
And no, they are not equivalent. Within classical mechanics the Newtonian equivalence principle results in the same trajectory for every point mass starting from same position with same velocity. Therefore it full includes the Galilean equivalence principle. But the Newtonian equivalence principle also results in the same acceleration for every point mass at the same position independent from its velocity. The Galilean equivalence principle does not say or require something like that and therefore does not full include the Newtonian equivalence principle. Furthermore this additional consequence of the Newtonian equivalence principle can not be tested with the Eotvos experiment.
  • #90
Thanks for the link atyy, but high energy physics is over my head.
I've never seen that before. Do you have a reference?
We may just have to agree to disagree DrStupid. I'll have to admit though that I'm not sure I've ever heard of the term "Newtonian equivalence principle" prior to this thread. I've always thought that Newton's experiments were just confirming Galileo's. I know from Newton's Principia that he did pendulum experiments using bobs made of different materials, which in effect would be the same as doing free fall experiments. And the UFF is a consequence of passive gravitational mass = inertial mass. Is there something else that he did that would set his equivalence experiments apart from Galileo's?
  • · Replies 22 ·
  • · Replies 18 ·
  • · Replies 114 ·
