Interesting Question About Relativity and the Absolute
In summary: So basically, the length that an object has "inherently", regardless of the observer's frame of reference, is the pythagorean sum of the measured spatial and time lengths.
Curious6
184
According to special relativity, distances are relative, as people measuring distance from different reference frames come up with different measurements and are equal on footing as regards their results. However, my question is then: how can we even define a given length, for example, the Planck length to be 10^-33 cm, if it is also subject to special relativity and therefore not even an absolute reference? Also (this is more of a philosophical question), can length even be assigned as a quality of an object or is it just an illusion from our reference frame?
Thanks for your insights.
Let me try to rephrase the question in a more meaningful way: if space is relative, then can we say quarks (or strings, or whatever the smallest constituent of the world is) don't have a length, as it all depends on the reference frame? This however leads me to ask the following: an object existing must have some sort of inherent length to it, or can it vary infinitely depending on the reference frame?
Please, someone help me out, I'm very confused!
"Proper length" is the term used for a body's invariant length. Although a body's length will change with respect to an observer, it does have a proper length, and that is a body's length with respect to itself, or its length when at rest.
For example, if you lay down on a spaceship going at 90% the speed of light, you'll look squished up to us because your relative height will be smaller than it was when you were on Earth. But you won't look squished up to yourself. You'll still be able to measure your proper height and you'll measure the same height for yourself on the spaceship as you'll measure on Earth or anywhere (with the exception of extreme gravitational fields that may even distort your point of view).
For consistency the Planck length has to be that measured in the rest frame.
Garth
...and is in fact the pythagorean sum of measured spatial length: [tex]l_{spatial}=\frac{l_{proper}}{\gamma}[/tex]
and [itex]c[/itex] times the velocity-induced non-simultaneity ("time-length"): [tex]l_{time}=c\frac{\gamma vl_{spatial}}{c^2}=\frac{vl_{proper}}{c}[/tex]
or: [tex]\sqrt{\left(\frac{l_{proper}}{\gamma}\right)^2+\left(\frac{vl_{proper}}{c}\right)^2}=l_{proper}[/tex]
([itex]\gamma=1/\sqrt{1-v^2/c^2}[/itex] as usual)
OK, thanks for clearing up this doubt. It was this concept of 'proper length' I was doubting about.
Related to Interesting Question About Relativity and the Absolute
1. What is relativity and how does it relate to the concept of absoluteness?
Relativity is a fundamental principle in physics that explains the relationship between space and time. It states that the laws of physics are the same for all observers in uniform motion, regardless of their relative position or velocity. The concept of absoluteness, on the other hand, is the idea that there are absolute truths or values that are independent of human perception or interpretation. In the theory of relativity, the idea of absoluteness is challenged as it suggests that there is no universal reference frame and that all observations are relative to the observer's frame of reference.
2. How did Einstein's theory of relativity revolutionize our understanding of the universe?
Einstein's theory of relativity, specifically the theory of general relativity, revolutionized our understanding of the universe by providing a new framework for understanding gravity. It also predicted the existence of black holes and the expansion of the universe. The theory of relativity also helped to reconcile discrepancies between classical mechanics and electromagnetism, leading to the development of new theories such as quantum mechanics.
3. Can the concept of absoluteness be applied to all aspects of physics?
No, the concept of absoluteness cannot be applied to all aspects of physics. The theory of relativity has shown that the laws of physics are relative and dependent on the observer's frame of reference. This means that there is no absolute truth or value in physics, and different observers may have different interpretations of the same physical phenomenon.
4. How does the theory of relativity impact our daily lives?
The theory of relativity has several practical applications that impact our daily lives. For example, the theory is used in GPS technology to accurately calculate positions and time, taking into account the effects of relativity on the satellites. It also plays a crucial role in the development of nuclear energy and technology, as well as in the understanding of the behavior of objects moving at high speeds, such as satellites and spacecraft.
5. Is the concept of absoluteness still relevant in modern physics?
The concept of absoluteness is still relevant in modern physics, but it has been challenged and redefined by the theory of relativity. While there may not be absolute truths or values in physics, there are still fundamental constants and principles that are universally applicable, such as the speed of light and the laws of thermodynamics. The concept of relativism has also influenced other fields, such as philosophy and psychology, leading to new perspectives on reality and human perception.
