Invisibility Cloaks: Understand How They Work
  • Thread starter Thread starter bassim22
Invisibility cloaks utilize advanced materials to manipulate light, allowing objects to become less visible or seemingly disappear. These cloaks often rely on metamaterials, which can bend light around an object, creating the illusion of invisibility. The discussion emphasizes the importance of understanding the basic principles of optics and light manipulation without delving into overly complex scientific jargon. Simplified explanations can help in grasping how these technologies function, making them accessible for educational purposes. Overall, invisibility cloaks represent a fascinating intersection of physics and engineering.
bassim22
Invisibilty cloaks ?
Hey i have a school homework which is : to do a presentation about
HOW do Invisibility Cloaks work ??
OFC i searched on the net but all what i found is VERY VERY complicated explanations !
so please i want a detailed explintations and at the same time not to be very complicated ( SIMPLE)
thank you
Welcome.
We cannot do your homework for you, but we can assist you. Put forth some of your ideas and we'll discuss them.
thank you
Here's a recent thread from one of our sub-forums where the concept was discussed:
https://www.physicsforums.com/showthread.php?t=469555
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
