Irodov 1.23 confusion: Calculate distance traveled and time elapsed for this decelerating particle
  • Thread starter Thread starter anthraxiom
The discussion centers on a physics problem involving a decelerating particle, where the user successfully calculates the time taken to stop but struggles with the distance traveled. The user integrates the equations of motion but arrives at an incorrect conclusion that the distance is zero when time is substituted, indicating a mistake in their approach. A key error identified is the omission of the lower integration limit during the calculation of distance. This oversight is crucial, as it leads to the incorrect result, and the user expresses relief upon receiving clarification. The thread highlights the importance of careful integration limits in solving physics problems.
anthraxiom
A point moves rectilinearly with deceleration whose modulus depends on the velocity v of the particle as shown in book, where a is a positive constant. At the initial moment the velocity of the point is equal to v0. What distance will it traverse before it stops? What time will it take to cover that distance?
acceleration=dv/dt=vdv/ds
v=ds/dt
I solved the for time but for distance am quite confused on why the approach im trying doesn't work.
First, let acceleration=w
w=-a√v
w=dv/dt=-a√v
rearranging, √v dv=-a dt
integrating both sides,
v0V∫√v dv=0T∫-a dt
where V is some arbitrary velocity at time T.
we get, (2√V)-(2√v0)=-aT------eqn 1
now we want to find time when V=0
putting V=0,
aT=2√v0
T=(2√v0)/a
now, to find distance, i took equation 1 and rearranged.
2(ds/dt)1/2=-aT+2√v0
squaring both sides,
ds/dt=(2√v0-aT)2/4
integrating,
s=(1/4)∫(2√v0-aT)2 dt where s is distance travelled
let (2√v0-aT)2=u
du/dt=-a
dt=du/-a
putting, (1/4)∫(2√v0-aT)2dt=-(1/4a)∫u2 du
this gives, s=-1/12((2√v0-aT)2)3
putting t=(2√v0)/a, we get s=0 which simply isnt possible and is the wrong answer. Can anyone tell me the mistake in my approach?
p.s. i know how to solve it using w=vdv/dt so please don't give me that solution.
Thanks
anthraxiom said:
Homework Statement: A point moves rectilinearly with deceleration whose modulus depends on the velocity v of the particle as shown in book, where a is a positive constant. At the initial moment the velocity of the point is equal to v0. What distance will it traverse before it stops? What time will it take to cover that distance?
Relevant Equations: acceleration=dv/dt=vdv/ds
v=ds/dt
w=-a√v
w=dv/dt=-a√v
v0V∫√v dv=0T∫-a dt
putting V=0,
aT=2√v0
T=(2√v0)/a
ds/dt=(2√v0-aT)2/4
integrating,
let (2√v0-aT)2=u
du/dt=-a
dt=du/-a
Thanks
In integrating to get s, you forgot to apply the lower integration limit at t=0.
Oh thank you so much I've been banging my head about this for 3 hours.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
