Is a point of inflection concave or convex? - Which answer is correct?
A point of inflection does not necessarily require the existence of an inflection point if the function has undefined areas. The discussion emphasizes the importance of analyzing the second derivative to determine concavity or convexity in different intervals. Some participants express frustration over the complexity of identifying these points, leading to confusion. It is highlighted that spending excessive time on such problems without clear solutions can be unproductive. Understanding the behavior of the second derivative is crucial for accurately determining concavity and convexity.
Sarah66
Hello everybody, :)
I have a problem with determining the intervals of convexity and concavity of this function:
there are no inflection points here for me
but for me there is no solution to this inequality...
I never wait for a ready answer but I've already spent 4 hours on it and I still don't know what to mark...
There doesn’t need to be an inflection point to switch between concave and convex if there are points where the function is undefined.
Check the sign of the 2nd derivative on each interval if you aren't sure.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
