Is Global Warming a Swindle?
In summary: The climate scientists seem quite convinced, and that's good enough for me.The arguments in the film are mainly comprised of ad hominems directed at the environmental movement and of long-discredited notions.The biggest problem with the film is that all but one of the "scientists" presented in the field are not climatologists. To anyone who thinks that their arguments hold water, I issue a challenge: find one paper in a peer-reviewed journal in the last five years which disputes anthropogenic global warming. If there really is a debate in the climatology community, then it shouldn't be too hard, right?In summary, the film "The Great Global
  • #71
The Great Global Warming Swindle Swindle
According to Carl Wunsch, MIT oceanographer, much of the material which he contributed to the "Swindle" documentary was highly edited.
In the part of The Great Climate Change Swindle where I am describing the fact that the ocean tends to expel carbon dioxide where it is warm, and to absorb it where it is cold, my intent was to explain that warming the ocean could be dangerous - because it is such a gigantic reservoir of carbon. By its placement in the film, it appears that I am saying that since carbon dioxide exists in the ocean in such large quantities, human influence must not be very important - diametrically opposite to the point I was making - which is that global warming is both real and threatening.
http://comment.independent.co.uk/commentators/article2359057.ece
  • #72
Art said:
See now we are getting somewhere add in solar variation and suddenly CO2 begins to look like a very small player in the GW drama. Although climate scientists have belatedly started adding to some degree solar variation to their models, which incredibly they haven't in the past, they still do not model clouds in any detail as they are too 'complicated' even though water vapor by their own models is by far the biggest greenhouse gas.
Don't you think that's a little like performing an autopsy on a corpse and ignoring the bullet holes because they are complicated, whilst trying to determine the cause of death :biggrin:
Solar variation? Are you referring to the 11-year cycle? The one which wasn't even directly (not via counting sunspots) detectable until recently? The one where we are currently near a minima? :smile: I suppose everyone except Lee Harvey Oswald shot JFK?
You shouldn't be suprised by your befuddlement with data. You're not an expert, and you don't know what you're talking about. I'm not either. The fact is, unless you go and earn a PhD in a quantitative science, gain employment as a climate scientist, and publish original research in a PR journal, you're not qualified to have your own opinion on it.
  • #73
ShawnD said:
First you said coal power plants create ozone. Ozone is created by UV and high voltage sources (such as power lines connect to hydro-electric powerplants), and ozone is destroyed by almost any organic molecules in air (this is why you can't smell ozone from across the room, you need to put your nose right upagainst the air purifier or television screen).
Then you said ozone is a major health issue, even though it's used to clean the air in hospitals because ozone quickly removes itself by reacting with everything.
Then you said CO2 is a pollutant beacuse it may have negative health effects when you live in an enclosed area. What exactly does that mean? Where I live, Earth, people live in open systems that are exposed to the atmopshere. Unless your house is completely air tight, your air is roughly the same 0.05% carbon dioxide as my air. It's true that in offices the concentrations tend to be about double that, but complaints about stuffiness and poor air have more to do with a lack of oxygen than an abundance of CO2.
I don't know anything about ozone, but I know coal power plant ash is radioactive (I just got a tour of my local power plant, in fact). Also, where I live, there is an http://en.wikipedia.org/wiki/Temperature_inversion" in the winter because it gets so cold here that we basically sit in a bowl of very low energy atmosphere (no wind near ground level). This causes a closed-system layer between the ground and the the top of the inversion.
My point here is that it depends on your location. You especially can't expect to understand how atmosphere work at the poles if you're at the equator or vice versa.
That's just one example of how complicated a model of the atmosphere might be, though. If you try to make assumptions on a global scale, you're going to have to consider millions of things like that, all dynamically interacting with each other.
Then you have to have the thousands of different scientists working on it put the data together in a reasonable way (this sounds kind of tricky to me, considering every different group will have their own methods for both data collection and analysis and they live in different nations, seeking different degrees of truth, speaking different languages.)
I'm not surprised there's no obvious consensus (though, for all I know, there may be 100% consensus among rational scientists.)
  • #74
do you smell ozone right after a lightining storm? it's what gives that fresh air smell.
  • #75
Err you have heard of the Maunder Minimum, right? And the Dalton Mininum and the current period of high solar activity (highest in 8000 years) known as the Modern Maximum which began in 1950 and is expected to run until 2030.
You are also aware the Earth's magnetic field has decreased in strength by 10% over the past 100 years reducing it's ability to trap cosmic particles which are known to play a key role in cloud formation, right??
You are also no doubt aware of the graph produced by Friis-Christensen and Lassen 1994 showing a direct relationship between solar activity and Earth temperatures over the previous 140 years and the Harold Jeffreys Lectures on the links between our climate and the behaviour of the Sun, from the perspective of a solar physicist.
And of course you must be familiar with the study done on temperature responses to quasi-100-yr solar variability during the past 6000 years based on d18O of peat cellulose in Hongyuan, eastern Qinghai-Tibet plateau, China which concluded solar activity is the primary driving force of climate change http://ff.org/centers/csspp/library/co2weekly/20060105/20060105_15.html
Or do you simply not have the faintest idea of what you are talking about and so keep simply repeating the same mantra??
Please try not to assume that everybody shares your ignorance of a topic you choose to comment on. Just because you do not know something doesn't mean it's unknowable.
  • #76
Art said:
Ah, but the point you missed is I didn't just pluck numbers out of the air.
I didn't expect that you did, but until you source your data, it makes no difference.
Art said:
Actualy I didn't ask, StuMyers offered and I accepted whereupon he withdrew his offer.
Was this by PM? I don't see any such offer. :confused:
  • #77
Then again you also seem to have missed the sources I provided upon request. In fact I seem to be the only one being asked for and/or actually providing sources. As for the offer - If one ignores the little jibe at the end you can see he did indeed make the offer
I can try and go through them one by one. I'm not by any means an expert, but based on what you write, I don't think you really need one.
  • #78
Yes, I do actually. I also know that IPCC TAR's analysis puts solar forcing at a full order of magnitude lower than that from CO2. Look it up.
I don't know anything about changing magnetic fields affecting cloud formation. I'm not qualified to judge the data. The difference between us, is that I know that. If the majority of CS's tell me it's important, I'll go along with it. If the consesnus says no, I'll go along with that too.
You can also go out and find contrarian arguments making the case against evolution or for a 6000-yr old Earth (usually all from the same folks). Doesn't mean these issues are in any kind of meaningful doubt.
On the contrary, I know exactly enough to know how much I don't. Maybe to you, finding one dubious report or analysis that claims 'B' is enough to go against the overwhelming consensus of 'A'. In my experience, that's usually because you don't really understand either, and are choosing the one which you 'like'. Both are black boxes, so to speak, so they appear to weigh equally.
I'm not giving an opinion. I don't know enough to do so. I can only look up and state the consesnus view.
  • #79
This case seems akin to having Lee Harvey Oswald, in the book depository, with the smoking rifle, and insisting he's innocent because someone heard an echo in the grassy knoll. :smile:
  • #80
consensus? I don't believe that's part of the scientific method. Perhaps in the post modern science
http://www.melaniephillips.com/diary/?p=1469
But that's not that modern, the same applied for tracking down witches in the dark ages.
However, I believe there is some faint consensus about the principles of the scientific philosophy of Karl Popper, Science is about the impossibility to prove theories, but theories are falsifiable..
The theory in question is that doubling CO2 in the atmosphere will cause a global temperature increase in the range of some 2-4 degrees Celsius. There is also some pretty common idea that under primary conditions, without feedback, the temperature increase would be in the order of magnitude of one degree, too insignificant to worry about. Hence we need "positive" feedback to attain those "dangerous" temperature increases.
I intend to open a thread later today in the Earth science realm (you should visit that more often) with the intention to demonstrate that system response characteristics should falsify this positive feedback.
If we agree that the data are right and are correctly depicting the situation, then this should also falsify the aforementioned theory.
  • #81
Yes I think that sums up your position very nicely, well done!
Now unless you are prepared to address the points I have made with something other than hand waving and adopting a position akin to Tomlinson's ghost I see no point in my wasting any more time responding to your posts.
"O I have a friend on Earth," he said, "that was my priest and guide,
"And well would he answer all for me if he were at my side."
http://www.sff.net/people/DoyleMacdonald/l_tomlin.htm
  • #82
I believe the fallacy is called "guilt by association". Remarkble is the role of fallacies in propagating the global warming myth.
  • #83
Yes, you provided some sources afterwards, and I haven't looked at them yet, but as long as the data is sourced, I'm happy. I didn't miss that. But naturally, if you write up a list of vague and imprecisely worded statements and ask someone else to explain them, you darn well provide sources for these statements.
The post you quoted was written after you posted your shopping list and asked Stu to throw light on it (ie: he didn't make any offer before you asked him to explain your claims).
In any case, as long as the points are properly sourced, I've got no complaints.
  • #84
After watching this documentary, I thought that the third world arc was interesting and provided some valid points.
  • #85
It's here
  • #86
I'm not a climate scientist making a scientific case. I'm just some guy on the internet making a joke.
And you? Are you in any way qualified, academically or professionally, to analyze data and draw a meaningful conclusion? And before you start dusting off your filosofy terms about argument from authority, be advised that I'm not a self-declared expert, and thus am not qualified to draw my own conclusions. This is why I seek the advise of an expert. Experts and laymen do not argue on equal terms.
Off the top of my head, even I could see that your talking points were disjointed and out of context. The fact that you would mention Cambrian climate or thickening ice sheets, two very silly arguments, easily refuted by about 10 seconds of thought or google research, suggests to me that you are simply out to collect unrigorous talking points that you think support your case.
Are you also aware of Martian global warming? I'm suprised you didn't mention that one, since it seems to be the contrarian argument du-jour.
http://www.heartland.org/Article.cfm?artId=17977
  • #87
It's true that consensus was not always part of the scientific method (especially since it was only rich people with spare time that did science back in the day) but nowadays, there's clear enough consensus in many subjects:
The sun is a fusion reaction (there's a small amount of people who are still trying to claim it's an electric energy source, but they're obviously crackpots)
The Earth is round (ever heard of the hollow Earth society? how about the flat Earth society? These people are not the majority, but they're loud enough to be heard and followed by uneducated people)
The universe is random (Schroedinger's cat; naturally, religions involving fate don't like the implications of this.)
The Big bang (most people arguing against this have a less-believable alternative called intelligent design)Notice that these are all things that were discovered, theorized, and experimented more than fifty years ago. Global warming is a baby. Everyone that's jumping on their respective bandwagon's right now (that are not professionals) become highly suspect.
Also, the people that are taught to make good arguments aren't necessarily the people who know what they're talking about. Winning an argument and being right are two entirely different things.
I have never, in my scientific training, been taught persuasive techniques. I come here to discuss and chew on the topic, not to try and convince other people that they're wrong and throw insults at them (accusing them of dogmatic practices for instance).
I'm here to listen and convince people to really question whether they know what they're talking about.
  • #88
It's also probably useful to note that it's different to say "99% of all people think X" than it is to say "99% of all experts in the field think X", when you're not in the peer group.
In science, non-experts can simply not argue on equal footing with experts. I've spent the better part of a decade becoming an expert in a specialized field, and I know for sure that you cannot argue in MY specialty on equal terms, just by reading pop sci or political talking points.
  • #89
I find it funny that you say that someone that is not an expert is not qualified to form an opinion, then proceed with your opinion. You are selecting what "you" want to believe and exclaiming your version of the truth is the "only, correct and true" version. Truth is, no one knows for sure what effect man made pollution is having, they can only guess.
Did you read the UN report on cows being a major factor in global warming? Is it ok to accept some reports coming from the UN and ignore others depending on what you want to believe?
Livestock a major threat to environment
Remedies urgently needed
"Which causes more greenhouse gas emissions, rearing cattle or driving cars?
Surprise!
According to a new report published by the United Nations Food and Agriculture Organization, the livestock sector generates more greenhouse gas emissions as measured in CO2 equivalent – 18 percent – than transport."
"When emissions from land use and land use change are included, the livestock sector accounts for 9 percent of CO2 deriving from human-related activities, but produces a much larger share of even more harmful greenhouse gases. It generates 65 percent of human-related nitrous oxide, which has 296 times the Global Warming Potential (GWP) of CO2. Most of this comes from manure.
And it accounts for respectively 37 percent of all human-induced methane (23 times as warming as CO2),
which is largely produced by the digestive system of ruminants, and 64 percent of ammonia, which contributes significantly to acid rain.
Livestock now use 30 percent of the earth’s entire land surface, mostly permanent pasture but also including 33 percent of the global arable land used to producing feed for livestock, the report notes. As forests are cleared to create new pastures, it is a major driver of deforestation, especially in Latin America where, for example, some 70 percent of former forests in the Amazon have been turned over to grazing."
http://www.fao.org/newsroom/en/news/2006/1000448/index.html
I don't see AL Gore screaming for a massive slaughter of cows to stop this DISASTROUS bovine cause of global warming. The cows are killing us! :rolleyes:
Why is Al not screaming about this? Perhaps cow farts and poop are not as glamorous as coal.
  • #90
Barbeque! :biggrin:
I'll bring the beer and picante (habanero) BBQ sauce!
  • #91
What opinion? I'm not stating my opinion on AGW. I'm stating the consensus view.
I want to think that AGW isn't correct. What I want however, is irrelevant.
And... not all guesses are created equal.
  • #92
Astronuc said:
Barbeque! :biggrin:
Do you have a wind-powered BBQ? You'd better not be burning coal!
  • #93
What does the "consensus" view have to do with anything? The fact that a lot of scientists have caught onto the fact that they can get more grant money and secure their jobs by "jumping on the bandwagon" does not mean they even actually believe in it. It takes a LOT more guts for a scientist to speak against the popular consensus.
I'm all for doing something about pollution, but I am not for "chicken little" scare tactics that are heading off down the wrong path in the name of popularity. People need to look at what is REALLY happening.
Emmisions from cattle are well documented, but ignored by politicians. Why?
  • #94
I'm doing my part by eating it rare.
Astronuc said:
Barbeque! :biggrin:
I know turbo will be more than happy to help. I KNOW that Ivan and Integral routinely do their part in reducing the cow population.
Seriously, a level headed look into what is causing the most pollution and how it can be curtailed is what we should be doing. THAT is why I am against all this political hype.
  • #95
Have you been reading Michael Crichton? He writes science fiction. :smile:
  • #96
I abhor fanaticism and tend to prefer to remain middle of the road, now PETA has gotten involved. I'm all for animal rights but again, moderation, moderation, moderation. Why do people have to go off the deep end? The following post I found actually sums things up nicely, and I have to link to the source (just found it through google), I am NOT endorsing this site.
"I'm sorry to be redundant about this, but I don't think people fully appreciate the logic. Meat eating is either the number one cause of GW or it is not. If it is the number one cause, then why are the GW people not talking about it? Even the skeptics are not focusing on meat as they should be. I think meat may be the Achilles Heel of GW, as it puts the lie to them. The skeptics should be pressing it. I think the logic is being blurred for several reasons. One is that lot of people think we should conserve (we should), and end our dependence on foreign oil (we should). This does not mean that CO2 is being released in sufficient quantities to cause climate change, though. People rationalize going along with the GW scare because we need to conserve, and they forget that conservation of oil is a different issue. (I think it's right to conserve oil and reduce dependency, but I think fudging the issue is manipulative.)
Another reason is that even the believers have a natural resistence to giving up meat, and they fear it will damage their movement. They want to keep it quiet, and for some strange reason, their opponents go along with keeping it quiet, probably because they think the less said about it the better. Big mistake IMO, especially if meat is in fact the Achilles Heel of the environmentalists. The American people are used to being scolded about oil, but if they're asked to give up meat, they'll begin to wise up, and start asking basic questions. It's this "leave well enough alone" mindset which prevents people from getting to the truth.
Finally, there's a natural inclination to think of oil as the culprit, not just because Big Oil is so widely demonized, but because we've all been conditioned from childhood to think of smokestacks and tailpipes as pouring out evil, filthy pollution. Never mind that we emit carbons and that they're organic. Oil companies are "bad." Farmers are "good."
Thus, it is counterintuitive to see meat as the problem. Frankly, I don't think man's oil consumption or meat consumption emits enough carbon to change the climate. But I believe in being fair."
http://www.classicalvalues.com/archives/004744.html
  • #97
And the number one, most significant cause of pollution is... drum roll... people.
Are politicians addressing world population? Nope. Not popular. Of course.
  • #98
Any time (like just now) I come upon something relevant to this list, I'll share. It is my opinion though, that the person most capable of debunking many points on this list is Andre.
Art said:
Perhaps from the knowledge you gleaned at these lectures you might be able to throw some light on the following?
The current average temperature rise of .13 C per decade is the same now as it was in 1910 when reliable records began.
From the 2007 IPCC report:
IPCC said:
The linear warming trend over the last 50 years (0.13 [0.10 to 0.16]°C per decade) is nearly twice that for the last 100 years.
This directly contradicts the assertion that the trend has been "constant" over the last century.
Art said:
The temperatures the UN uses to calculate average global temperatures are obtained from readings taken near expanding towns and cities which makes the data victim to the heat island effect which is potentially serious as it is possible that the Earth is actually cooling not warming.
The error bars due to the heat island effect are calculated and specified in the same report.
IPCC said:
Urban heat island effects are real but local, and have a negligible influence (less than 0.006°C per decade over land and zero over the oceans) on these values.
Both quotes are from here: http://ipcc-wg1.ucar.edu/wg1/docs/WG1AR4_SPM_PlenaryApproved.pdf - pg4
  • #99
From the 2007 IPCC report:This directly contradicts the assertion that the trend has been "constant" over the last century.
That's a blatant strawman argument. I never said it was constant. I said it is the same now as in 1910.
According to the U.S. EPA the heat island effect accounts for between 1 - 6 C differences between urban and rural areas. Hence as cities grow one would expect temperatures measured within these cities and in surrounding areas to rise. The fact that largely they haven't is why some think temperatures may actually be falling. http://www.epa.gov/heatislands/
btw Seeing as how it is the veracity and conclusions of the IPCC's report I am questioning quoting them as the authoratitive source seems somewhat pointless.
  • #100
No, it's a desperate attempt at gleaning some kind of meaningful argument from your pointer.
Now that's a non-argument, and is the reason why I attempted to interpret it in some kind of meaningful manner. If your pointer (as you now assert) has nothing to do with trends in global temperature rise, why did you include it? Beats me! If there is an argument in there, it would have helped if you made it clear. Anyone knows that the existence of two points with the same slope says nothing about the trend of the curve.
Besides, if "reliable" records began only in 1910, how did you compute a moving average for 1910? (Note: I didn't see this claim in your two sources, hence all this trouble with trying to interpret it meaningfully. The trouble could have been avoided if each pointer was individually sourced.)
I'm only pointing out that your pointer distorts what the study involves. Rather that saying there are people that predict a different magnitude for the heat island effect, you made it look like the data was used incorrectly because it didn't account for the heat island effect. I provided a link to the IPCC report to show that it DID account for the heat island effect.
This was part of my objection to the original list. By writing it imprecisely, you make it impossible to have a meaningful argument about it.
  • #101
Oh, yes! I don't know how much of an effect I have had on the cow population, personally, because farmers keep raising more, and that makes is hard to keep count. :-p Just doing a rough estimate, I figure that I've probably eaten at least 5000# of beef - that's only about 10 steers, lifetime. I guess, I'd better start ramping up the effort.
http://www.askthemeatman.com/yield_on_beef_carcass.htm
  • #102
Because emissions from cattle don't matter. The carbon dumped into the atmosphere by cattle comes from the food they eat, which comes from plants, which comes from the atmosphere. It's already part of the carbon cycle. Carbon emissions from oil and coal is coming from deep underground, and hasn't been in the ecosystem for millions of years. That's why it's causing a problem.
  • #103
For a somewhat more rigorous analysis of the urban heat island effect (or rather, non-effect).
AMJ Journal of climate.
http://ams.allenpress.com/perlserv/....1175/1520-0442(2003)016<2941:AOUVRI>2.0.CO;2
AMJ said:
Assessment of Urban Versus Rural In Situ Surface Temperatures in the Contiguous United States: No Difference Found
Thomas C. Peterson
National Climatic Data Center, Asheville, North Carolina
ABSTRACT
All analyses of the impact of urban heat islands (UHIs) on in situ temperature observations suffer from inhomogeneities or biases in the data. These inhomogeneities make urban heat island analyses difficult and can lead to erroneous conclusions. To remove the biases caused by differences in elevation, latitude, time of observation, instrumentation, and nonstandard siting, a variety of adjustments were applied to the data. The resultant data were the most thoroughly homogenized and the homogeneity adjustments were the most rigorously evaluated and thoroughly documented of any large-scale UHI analysis to date. Using satellite night-lights–derived urban/rural metadata, urban and rural temperatures from 289 stations in 40 clusters were compared using data from 1989 to 1991. Contrary to generally accepted wisdom, no statistically significant impact of urbanization could be found in annual temperatures. It is postulated that this is due to micro- and local-scale impacts dominating over the mesoscale urban heat island. Industrial sections of towns may well be significantly warmer than rural sites, but urban meteorological observations are more likely to be made within park cool islands than industrial regions.
  • #105
I'll post this again as you evidently missed it last time
The reason I didn't bother with detailed sources is because this is the political forum and my main point was that a lot of the hype around GW is being driven by a political agenda. My 'list' was simply to demonstrate the debate is far from over.
From 1910-1940 the temp rise per decade was as it is today. From the mid 40s to the mid 70s it plummeted leading all the 'chicken littles' to run around screaming 'the Earth is freezing, the Earth is freezing' then from the mid 70s to 1998 the temperature rose at the same rate as it did prior to the 'ice age' period leading the same 'chicken littles' to run around screaming ' the Earth is burning. the Earth is burning' since then it hasn't done a lot one way or the other.
As for the IPCC accounting for the heat island effect; well I suppose they did in a way, they said it was irrelevant :rolleyes:
