- #176
Mr. Robin Parsons
- 1,256
Heusdens, if at any pont the gravity is equal to zero, and there is pressure then it blows up, explodes, fracures out into lots of little pieces, gravity is what is holding it all together, by pressurization.
Newton did NOT know about Neutrons, Neutron Stars, Black Holes, The Big Bang, The currently known size of the Universe, The rest of the Galaxies out there, Stars using fusion as their source of power, Nuclear reactions, A bombs, H bombs, the internal structure of the Earth, the huge stell ball that is there, as measured, (RECENTLY!) He did not know a lot of the things that get taught in High School Science classes, right now.
I did the shell game calculation and it is very clear that if the gravity drops, off then the Earth IS hollow, and it Ain't! as there cannot be pressure, on matter, absent of gravity, as all of the pressurizations you see, anywhere, are a direct, and indirect, result, of what gravity, in atoms, does, NO exceptions!
Without the pressure that only gravity can cause, the heat (anti-pressure)there, would blow it apart!
Nigel, if your spatial pressurization, as per surface area worked, then I could take a 1 square meter piece of material, 1 mm thick, and find a ten fold difference, in it's weight, as per gravities pressurization on it, simply by standing it on it's edge, as opposed to laying it flat.
Sorry to tell you, it doesn't work that way, and that, too, is provable!
