I Is internal battery "emf" a conservative force?
The electric force established by a battery across its terminals is conservative, represented by the voltage potential V. However, a battery also converts chemical energy to provide electrical energy, which involves a "push" force on charges, distinct from electromotive force (emf). This "push" force is not a conservative force; rather, the electric field generated by the chemical reactions within the battery is non-conservative. The discussion confirms that while the electric field from a battery's terminals is conservative, the internal emf related to chemical reactions is not. Further references on this distinction are sought for deeper understanding.
STosh9
First, the electric/Coulomb force set up by a battery across its terminal is conservative, and its potential is given by the well-known V. I also understand the conventional usage of emf is as a voltage potential.
However, a battery does more than just set up the electric field and its associated voltage - it provides electrical energy, by conversion from its chemical energy, to push charges to higher potential. Is this "push" force on charges, or internal emf, a conservative force?
The push force and the electromotive force are not the same thing.
The former is electrostatic force, and the latter is voltage (energy-to-charge ratio).
No. Electric field due to the chemical reaction in the battery is non-conservative in nature.
Likes STosh9
Thanks cnh1995 for confirming my suspicion. Would you have any references handy that explains this more?
Assume that this is a case where by sheer coincidence, two sources of coherent single-frequency EM wave pulses with equal duration are both fired in opposing directions, with both carrying the same frequency and amplitude and orientation. These two waves meet head-on while moving in opposing directions, and their phases are precisely offset by 180 degrees so that each trough of one wave meets with the crest of the other. This should be true for both the electric and magnetic components of...
