Is movement really relative or absolute?
In summary: This appears to be personal speculation. Do you have a professional scientific reference that makes this sameprofessional scientific referenceNo, I do not.
only1god
43
I was discussing in another page this topic with someone. He said it's relative in everything, meaning that energy and force doesn't count. This is obviously wrong because the fact that today we can't (maybe tomorrow we can) know which thing is moving towards the other and which not, doesn't change the reality.
For example, when I'm driving my car things "seems" to be coming at me, the road seems to be moving under my car and i seem to be at rest, but this doesn't change that it's me who's moving, otherwise we wouldn't need to pay for fuel to move...
Another thing, Why was important changing from geocentrism to heliocentrism? We could just have stayed with the geocentric model.
What if you are standing on one of those airport-style travelators? That's powered by mains, presumably, so does that mean it's the Earth that's moving?
No, it's obviously right. You are confused because you apparently have not studied "frames of reference". From YOUR frame of reference, the road is moving. From the ROAD's frame of reference you are moving. Both of you are correct in saying that the other is moving. All motion is relative (although acceleration is absolute, but that's a whole 'nother issue).
Energy is relative even in Newtonian physics.
Force is frame invariant in Newtonian physics but relative in special relativity.
This “otherwise” statement is an incorrect conclusion. If you are in a car, it doesn’t matter what reference frame you use, you need the same amount of fuel regardless.
Besides, it is naive to think that the Earth is at rest. The Earth is spinning on its axis, that axis is orbiting the sun, the sun is orbiting the galaxy, the galaxy is moving within the galactic cluster, and the galactic cluster is moving relative to the CMB, and the CMB is expanding.
Staying within simple, Newtonian physics, force is related to acceleration, not to constant velocity. F=ma. You must specify what kind of motion you are talking about before you can consider if it is relative or not.
You pay for fuel to keep a car moving because you must oppose the forces (friction) that would otherwise slow it down. This is a question of acceleration/deceleration, not of constant velocity.
that was what i meant, perspective doesn't change reality
from our reference frame (earth) everything is orbiting around us...
And when I stand on my head everything is upside down. So what?
Likes PAllen
But both perspectives are compatible with the same reality. Your “otherwise” indicates that you think only one perspective explains why the car uses fuel. That is not correct. Both explain that same fact.
Yes. And that frame is no more or less valid than any other frame.
This only means that movement is absolute in reality and relative in perspective, but your perspective even if it's right does not change the fact of what's actually happening. This is what i was trying to explain...
  • Skeptical
Likes weirdoguy
No, it definitely does not mean that. Movement is relative in reality, not absolute in reality.
This appears to be personal speculation. Do you have a professional scientific reference that makes this same distinction?
So is the Earth orbiting around the sun or is the sun orbiting around us? from our perspective the sun is orbiting around us, but that doesn't change the fact that Earth is orbiting around the sun.
  • Skeptical
Likes weirdoguy
As i said, is geocentrism the same as heliocentrism?
  • Skeptical
Likes berkeman
As you do not have a professional scientific reference that supports your distinction, this thread is closed. I recommend that you read the forum rules before posting again. We are here to educate about mainstream science, not indulge in personal speculation.
Likes George Keeling
FAQ: Is movement really relative or absolute?
Movement is a concept that can be viewed from both relative and absolute perspectives. In the absolute sense, movement is defined as the change in position of an object in relation to a fixed point. In the relative sense, movement is defined as the change in position of an object in relation to another moving object.
What is the difference between relative and absolute movement?
The main difference between relative and absolute movement lies in the reference point used to measure the change in position. In absolute movement, a fixed point is used as the reference, while in relative movement, the reference point is another moving object.
How does Einstein's theory of relativity impact our understanding of movement?
Einstein's theory of relativity states that there is no absolute frame of reference in the universe, and all motion is relative. This means that the laws of physics are the same for all observers, regardless of their relative motion. This has a significant impact on our understanding of movement, as it challenges the traditional notion of absolute movement.
Can movement be both relative and absolute at the same time?
Yes, movement can be both relative and absolute at the same time. This is because an object can be moving relative to one reference point while also moving absolute to another reference point. For example, a car may be moving relative to a stationary tree, but it is also moving absolute to the Earth's axis as the Earth rotates.
How do we determine the speed of an object in relative and absolute terms?
In absolute terms, the speed of an object is calculated by dividing the distance traveled by the time taken. In relative terms, the speed is calculated by dividing the relative distance by the relative time. The relative distance and time are measured in relation to the reference point used for the relative movement.
