John421
- 12
- 0
I read that a voltmeter measures the voltage difference between two
points, but this doesn't make much sense to me. Let's take the following
picture:
http://www.bbc.co.uk/staticarchive/346c39cfd7376d612ba49cad06febd926fe7b9f6.gif
Would it make sense if the voltmeter was receiving current from both
sides, so that it could measure the kinetic energy difference of the
electrons it was receiving from each side, working out the difference in
voltage?
Would it make more sense to say that since components in parallel
receive the same voltage, we can assume that whatever the voltmeter is
getting, the bulb is also getting (in this case I don't see how the
voltmeter is actually measuring anything between two points but is
instead measuring what it's receiving and we assume the component is
getting the same voltage)?
Can you also assume that since voltage is divided between all components
in a series circuit, (and that the component eats all the voltage it is provided
with?), so you can assume that whatever the voltmeter is getting, the
measured component is using 100% of that voltage showing on the voltmeter?
Since kinetic energy (which I was taught was voltage) is converted into
different forms such as heat, would you say the voltage is actually used/eaten
by a component/resistor, but since I = V/R if voltage is reduced by a component
then the current in the circuit is reduced too (which would explain why
resistance lowers current)?
picture:
voltage?
