- #36
Sherlock
- 341
One thing I don't get is why/how OQM violating Bell Locality, (which I'll accept), necessarily leads to nature being nonlocal. It's clear that local hidden variable theories must satisfy Bell Locality. But hidden variables are based on the classical mechanical idea that a one to one mapping between theory and nature is possible. OQM prohibits such a one to one mapping (for reasons that I'm just beginning to understand).ttn said:"Bell Locality" is a particular definition of what it means for a theory to be local. So the obvious way to use it is to see if a theory satisfies it -- i.e., to see if a given theory is local.
Look, it's really simple. Forget for the moment about hidden variables and everything else. Suppose you accept "Bell Locality" as a definition of what it means for a theory to be local. Just look at orthodox QM and ask: is it Bell Local? Answer: no. Now you think: is there some way I could fiddle with QM (e.g., by adding hidden variables) in order to construct a Bell Local theory (making sure of course to stay true to the QM predictions since those are verified by experiment)? Answer: no. (Bell's theorem.) So no Bell Local theory can agree with experiment, whether it has hidden variables or not. There's no empirically viable theory that is Bell Local. So nature violates Bell Locality. QED.
Insofar as classical mechanics is valid, then the principle of locality holds. However, In the range of quantum phenomena, classical mechanics breaks down, and, if the principles of quantum theory are correct, there's not even the possibility of the sort of relationship between theory and nature that hidden variables require.
So what does it mean to say that OQM is Bell Nonlocal -- that is, when the Bell Locality test, P{A|a-hat} = P{A|a-hat, B, b-hat}, is applied to OQM, and OQM is thereby discerned to be 'nonlocal', then what's the physical meaning of the term 'nonlocal' in this context?
If you interpret it to mean that A and B are causally affecting each other in real space and time, then I would say that that interpretation isn't necessarily correct.
Something you seem to have glossed over, or just aren't considering (even though you're well aware of it) is that changes in the wave function of the AB system when either A or B has registered a detection are happening in an imaginary space.
The probability of A after B acquires a definite value is given by the unitary-space analogue of the square of the cosine of the angle between b-hat and a-hat. This is an underivable formal assumption of quantum theory (the basis for which, in the development of OQM, I'm also just learning).
Whether this axiom's physical (predictive) utility corresponds in any way to physically nonlocal phenomena is unknown (at least to me). So, pending a definitive assessment of that, the assumption that the natural universe obeys the principle of locality remains -- and the physical meaning of calling OQM a nonlocal theory based solely on the Bell Locality test remains unclear.
Sherlock said:It was known before Bell that hidden variable theories were incompatible with qm, wasn't it?
I asked the question because in the section of Bohm's Quantum Theory text entitled Proof that Quantum Theory is Inconsistent with Hidden Variables he says, "We conclude then that no theory of mechanically determined hidden variables can lead to all the results of the quantum theory." (The italics are Bohm's.)ttn said:Um, seeing as the statement is completely false, no, it wasn't known before Bell (nor after).
I've gotten some of the original papers contributing to the development of quantum theory. Hopefully these will give me a better idea of whether, and in what sense, to call qm a 'local' or a 'nonlocal' theory.
