Is stress a source of gravity?
In summary: Electric field effects. In addition, the electric field creates an additional quadrupolar moment Qe, orthogonal to Qm and Qs. The net effect is that the amplitude of GW's is proportional to the square of the electric field strength. This is not the case for stress, where the amplitude is proportional to the electric field strength multiplied by the stiffness of the material. This is independent of the material's electric resistance.In summary, the two types of GW's have different amplitudes as a function of the electric field strength.
  • #106
PeterDonis said:
It's true that *pressure* is not flowing from one place to another in your examples; but *stress-energy* is. The fact that the stress-energy changes form, so to speak, from pressure to something else and then back to pressure again, does not invalidate the applicable conservation laws.
As far as "source" goes, with respect to the Komar mass integral, once again, since the spacetime is not stationary, we can't expect that integral to be conserved. However, I think there's a fairly simple approximate picture of "where the source goes" in your scenario. I'll use the example with the two poles, and describe the key steps in the process:
Sorry, but you've completely missed some of the points in my earlier posts. The energy stored in the poles due to elasticity is not the same as the Komar "stress-energy", which is nominally equal to the potential energy. If it were, the pole would have been compressed to being of no thickness at all.
This "Komar stress-energy" is definitely NOT conserved. Momentum is conserved during the changes, but the integral of the stress-energy over a pole goes from the potential energy to zero when it is moved out of the way.
  • #107
PeterDonis said:
Yes, it does. It's in T_00, the time-time component of the SET. If the material is compressed, its density increases; that is reflected as an increase in T_00. If other (non-gravitational) field energies also increase, those increases will also show up as an increase in T_00.
I meant that any additional energy due to compression does not appear in the Komar stress-energy term. It does of course appear within the ordinary energy.
  • #108
Q-reeus said:
It seems you didn't get the message from my comments in #71. I deny not only the objective validity of every point(scoring) you make above, I despise the attitude behind them.
That much is certainly clear.
Q-reeus said:
You make it a habit not just in this thread but on numbers of others of continually raising false representations of what I both have said and mean
Whenever I have actually done that it has only been because you fail to present what you mean in a clear and unambiguous manner. This is also a common impediment to Peter Donis' efforts to communicate with you. When we try to make things clear and unambiguous by bringing in math, you reject all such attempts in preference for vague statements in English that inevitably leads to misunderstandings. One of the reasons for the math you avoid is precisely to eliminate this issue that you are complaining of here. I am willing to fix it, are you?
Q-reeus said:
- over and over in a deliberate campaign of psychological warfare by attrition. I'm thoroughly sick of having to trawl back through previous entries, just in order to show this or that statement of yours is bogus. And the longer the thread becomes, the more emotionally and physically enervating that becomes. Which I believe is your deliberate intent - get me to give up out of sheer exasperation.
My intent is actually to get you to stop trying to dodge the issue at hand. I do, in fact, hope that you find it psychologically uncomfortable, not to motivate you to leave, but to motivate you to actually confront the problem in your logic.
Q-reeus said:
Unless you arrange for my permanent ban here at PF - and I wouldn't put that past you. So here's my message to you DaleSpam: Draw up a list of persons you vow never to respond to - and make sure my name is at the top of the list. OK! (and I won't, out of reciprocity on that arrangement, bother to answer your #101).
I am not attempting to ban you, and have never done so. However, if you continue to post unsubstantiated nonsense claiming to debunk GR then I will continue to respond. If you continue to duck the issue then I will continue to point out that you are doing so.
So, are you either ready to post a proof justifying the approximation of using the Komar mass in a non-stationary spacetime, or do you conceed that the Komar mass is indeed undefined in a non-stationary spacetime? (of course, there is always the third option: to dodge the question and get angry at me personally).
  • #109
Q-reeus said:
Looking back over some recent and not so recent entries here, a pattern emerges. Beginning with myself then Jonathan Scott (and TrickyDicky with acute observations), Specific arguments of principle are raised via some simple gedanken experiments. The response in general (not by all) is to refer to the inapplicability of say Komar expression, without offering a viable alternative expression that is applicable. That or just saying that mass or energy or whatever is ill defined in GR in general - meaning the specific points raised are unresolvable in principle. An amazing stance from my pov. If it's the case that mass/energy-momentum etc is so ill-defined, then pray tell how is it that Birkhoff's theorem is not by that outlook also subject to uncertainty?. Strikes me as faintly rediculous to argue that Komar falls over because some ultra-tiny perturbation of spacetime is present somewhere. No qualitative or quantitative justification for showing any such tiny pertubations should be treated no differently than in other disciplines (EM, mechanics), as something rightly ignored in context. Not adding up imo. And of course I've had it continually thrown in my face that it's up to me to provide a rigorously mathematical proof.Will someone do what I asked back in #1 - point to which SET terms, for either example [1] or [2], can be shown to offer parameter independent cancellation of pressure, so as to specifically justify Birkhoff's theorem? And please take note of a point raised time and again - I for one do not accept as valid overthrowing a counterexample by the very theorem that counterexample is calling into question. Please, someone out there in PF land - deal with the specifics of the two examples given back in #1 + #69. Show just specifically how it all comes out right for GR - or not! I don't enjoy continually repeating on this - tackle the specifics. And if it's felt that ADM or whatever is a better model to use, go ahead and work from that - justifying it's use. Failure to show how any other terms can reasonably act to cancel pressure should be a sign something is wrong, not with my offering, but GR.
Let's recall exactly what Birkhoff's theorem says wrt what we are discussing here. The theorem which has been proved in many different ways, says in lay terms that a spherically symmetric vibrating shell (monopole radial pulsations which would be the only possible ones) in vacuum cannot propagate any disturbance into the surrounding space. This amounts to saying that the very spherical symmetry of the system cancels any spherically symmetric disturbance, so there is no such thing as a monopole GW if we want to keep the system spherically symmetric, this also guarantees any exterior metric to the shell must be static.
This is usually understood in the sense that in the exterior of a spherically symmetric shell there is no notion of the interior radial magnitude of the shell and therefore there's no way for the metric to propagate a perturbation of it.
Note that even in not-vacuum solutions of the EFE with spherical symmetry like FRW metric there is no propagation of GWs (only for perturbed forms there are).
All these are purely geometric results independent of GR as a physical theory.
  • #110
Jonathan Scott, sorry, I was going to respond to your post of long ago to me, but I got wrapped up in the struggle to get Q-reeus' to actually confront the issue of the validity of the Komar mass.
I have found that the best way to think of the divergence of the stress energy tensor is to think of a 4D box around a region of spacetime (not necessarily small). The 4 divergence being 0 says that any energy or momentum which enters one side of the box will leave another side of the box. It is important to recognize that a stress is the same as a momentum flux.
So, suppose that you have a stress which suddenly increases. Thinking in 4D, that means that one side of our box has two regions, the region of low momentum flux and the region of high flux. By the 4-divergence, this increased momentum flux in the side of the box must correspond to increased flux out of some other side of the box. There are two possibilities, either it can go out one of the other spatial sides of the box, i.e. a corresponding stress change on that side, or it can go out the time side of the box, i.e. a change in the momentum of the material leaving the box.
You can make that box as small or as large as you like, and the principle will hold. Any change on one side must be balanced by a corresponding change on another side.
  • #111
I thought I already explained that earlier, with a similar description, for the benefit of PeterDonis, who seems to be having a problem with it. That model describes how each component of momentum is conserved, and similarly the divergence of the energy-momentum row shows how energy is conserved. It does NOT say that the volume integral of the normal stress (which is what we are using in the Komar mass expression) is conserved, and my "pole" models illustrate clearly that it is not in fact conserved.
  • #112
And? It is well known that Komar mass is not conserved in non-stationary spacetime. That's why it shouldn't be used for such a scenario.
  • #113
DaleSpam said:
Not giving up on me it seems. OK DaleSpam, I'm touched enough to break my own vow and give this another shot. Doubtless will regret it. Just don't expect me to go trawling like I have - it's just not worth it personally. Some comments on your #108:
It's finally dawning on me the level to which I am dealing with particular mindsets that simply cannot conceive of the possibility of any consequential flaw in GR. Just cannot be. Hence the demand for a rigorous high level maths proof from me, knowing that will not be forthcoming. You and Peter and others here at times freely use simple non-rigorous arguments where it suits, so yes I'm more than annoyed when there is carte blanche refusal to meet me at that level. Emotive words, combined with obstinate rejection of a straight forward request - show where there is some basic error in logic in #1,69. Point to precisely where and how they fail, and I might take some of your less pejorative comments above seriously. And Peter is well aware of the trouble I had just trying to get acceptance of the correct basic stress distribution in a shell. It was painfully circuitous and I have no patience left for the 'yes-it-is, no-it-isn't', 'yes-you-did', no-I-didn't' situations that developed there.
You just don't get it. Any rigorous math proof acceptable to you and others here would entail working within a framework gauranteed to self-exhonerate GR. What I have done is set out simple but I maintain logically rigorous counterexamples that try and break out of that circular bind. And no-one it seems, certainly not yourself, is prepared to specifically point to any failing in that logic. It is you and others that pointedly refuse to address the logic there. And how many times have I appealed by now? Don't ask. The 'logical' reaction that comes back to me is assertions that I'm stupid or bad or unreasonable or terribly incoherent, so why would anyone bother to deal straight with the specifics I present. Because that would be sensible and fair, that's why.
Quite a relief.
There you go again - pejorative words gauranteeing an angry reaction. When will you learn to be more circumspect? You know I'll just say you are ducking my challenge. And you know there is nothing I am ducking, no matter how many times you say otherwise.
Just read my above comments. And when you personally address the specifics raised in #1,69, as I asked in #71, there can be a proper basis for further discussion. If you are not prepared to do so, I'm entitled to conclude you cannot find a flaw, and certain conclusions follow. There is no doubt in my mind there has been a flurry of PM correspondence on that involving yourself. Yet no one steps up to address what is a simple argument. Be the hero and break this hoodoo DaleSpam, even if you fall bravely. Be the hero.
[Late edit: I see you're in good sniping form with your #110. Sigh.]
  • #114
Exactly. Q-reeus was clearly hoping it was at least "approximately" conserved, which is not the case. As I've previously mentioned in this thread, using the "poles" illustration, it isn't conserved when any motion or even acceleration is involved, even when the acceleration hasn't yet got anywhere.
There is a related puzzle that in the original stress-energy tensor this term appears to be part of the gravitational source term on the RHS of the Einstein equations, and I for one find it difficult to understand how something apparently non-conserved can be involved there. However, I know that's a very tricky area to understand, so I'm not expecting it to be solved in a PF thread.
  • #115
Yes I understand that IF there is zero fluctuation in gravitating mass m going on, everything you say makes perfect sense and I would never have used the oscillating shell model in #1. But the whole point of using it is as a nice test bed to check on BT via a consistent application of how SET terms are supposed to contribute there. As for the proofs of BT, there would need to be an explanation of just how that SET balancing act is incorporated for me to consider taking it as gospel. As I have said earlier in #76 and #105, if one can't find any reasonable way to balance SET terms yet maintain Birkhoff's theorem holds rigorously, it logically implies new, de facto SET terms are being invoked.
  • #116
Birkhoff's theorem does not assume this. It proves that the assumptions of spherical symmetry forces this to be true. You are interchanging conclusion with assumption.
I think the core of your error is reasoning from false premises: x appears in stress energy tensor, therefore contributes directly to gravitating mass; Komar mass formula at least approximately describes mass for non-stationary situations. These are both simply false, while BT is a rigorous mathematical theorem. Also a pure math theorem is that ADM mass is conserved in asymptotically flat spacetime. Therefore, if you used ADM mass, you would find you whole argument about varying gravitational mass collapses. The ADM theorems help explain why BT works.
  • #117
You may have, I was too focused on the other discussion.
I cannot speak for PeterDonis. It sounds like you and I agree then, that the stress energy tensor is conserved. Specifically, it sounds like we agree that in the case of an instantaneous change in pressure the zero divergence of the stress-energy tensor still holds at each event without any sort of delay. Is that a correct representation of your opinion?
I agree and would go further. The Komar mass is only defined in a static spacetime, so not only is it not conserved in other spacetimes it doesn't even exist in them.
  • #118
I agree the zero divergence holds at all times, including for example cases where a wave of sudden pressure change is moving through the object (causing brief accelerations and slight readjustments of positions). However, I would describe this by saying that the energy and momentum described by the tensor are conserved (or that the flow of energy and momentum locally obey continuity equations), not that the "stress energy tensor is conserved", which I consider potentially confusing.
  • #119
PAllen said:
Q-reeus: "Yes I understand that IF there is zero fluctuation in gravitating mass m going on,"
Let's say this is correct. It should be possible then to pinpoint where the balance between a varying Komar mass and non-varying ADM mass is taken up. Given motion is invalidating Komar, it must be because certain SET terms behave differently under radial motion, agreed? So what are these motion dependent terms that compensate in a spherical geometry? Can we at least drill down that far? It's what I've basically been asking from the start. If SET terms acting as suggested above cannot be identified, then it follows there really are extra SET terms de facto introduced. For instance, if time-rate-of-change of a 'standard' SET term becomes a source, that becomes a distinctly different SET term. I'm talking here about 'new' SET terms - clearly radial motion of mass constitutes an energy-momentum flow there, which is just a standard SET term. Rate of change of that would not be. Anyone say otherwise?
  • #120
The Komar mass expression is mathematically equal to the conventionally expected value for the effective total mass-energy of a system, equal to the sum of the local mass-energy for each component minus the potential energy which would need to be extracted to form the system from components initially at infinity. This does not mean it is a true description of the arrangement of mass-energy within the system.
A similar scheme applies in electrostatics, where you can either view the energy distribution in terms of charges within potentials or in terms of the energy in the field, proportional to the square of the field locally. The two descriptions give equal results, but describe the energy as being differently located.
For your spherically symmetrical case, I don't have a problem with Birkhoff's result that a spherically symmetrical distribution of oscillation inwards and outwards momentum would give no overall effect on the external field, as the average motion over the whole spherical surface is zero, and similar symmetries probably apply to any stress terms. In GR, this effect cancels even more powerfully than in Newtonian theory, as the field due to a particular component particle effectively points to its anticipated position at the current time taking into account both velocity and acceleration, so the field is effectively that of a consistent "snapshot" of the whole sphere at a particular time, rather than seeing near and distant motions being out of phase.
  • #121
This doesn't make any sense to me. There is no concept of SET terms changing meaning that needs to be explained. There is just a specialized formula that can be used of none of the terms of T is time varying. Is this concept so hard to grasp? Instead, you can use ADM mass always - it applies to dynamic as well as stationary spacetimes. Any concept of directly relating terms of T to gravitational mass is wrong.
  • #122
That is fine by me. It is always difficult to put the math into words. I like the "locally obey continuity" one.
  • #123
AFAIK the ADM mass requires asymptotic flatness, so it cannot be used always, in particular not in the FRW spacetime with a nonzero cosmological constant.
  • #124
It is invalid because the timelike Killing vectors do not exist.
  • #125
I agree with this.
  • #126
I mention this many other posts. I got tired of always mentioning it. The 'always' here meant stationary or time varying.
  • #127
I agree that the volume integral of pressure (i.e., "normal stress") is not conserved; I didn't mean to imply that I was contesting that claim. I was only pointing out that the Komar integral is *not* just the volume integral of pressure; it includes the energy (T_00) in the integrand as well. However, we appear to agree that the Komar integral should not be expected to be conserved anyway in a non-stationary spacetime, so the point I was making is only a minor point.
  • #128
Actually, I not only can conceive of the possibility that GR is wrong, I completely expect it to be experimentally proven wrong at some point. The difference is that I recognize that GR cannot be attacked theoretically, only experimentally. The mathematical framework that defines GR ensures that it is a self-consistent theory. The only way to disprove GR is to show it to be inconsistent with experimental evidence.
Your basic error in logic in #1 is precisely when you use the Komar mass which is not defined in a non-stationary spacetime. You cannot possibly prove anything about GW's using the Komar mass because the first excludes the second.
I do get it, in fact, I agree 100%. That is precisely why so much effort goes into rigorously defining the mathematical framework of a theory. Once that has been done the theory is guaranteed to not have logical inconsistencies. If you would learn the math then you would understand that.
  • #129
Understood. I figured that you were aware.
  • #130
Just a brief comment: we are using non-rigorous arguments to counter similar non-rigorous arguments from you by casting a reasonable doubt on your premises. We are not using non-rigorous arguments as a basis for claiming we have *proved* anything. We're not the ones making positive claims; you are.
(Strictly speaking, that's not quite true; we have made some positive claims, for example I made the positive claim that Birkhoff's Theorem rules out the possibility of monopole GWs. But that positive claim is based on a rigorously proved theorem.)
  • #131
One other thought since the ADM mass has been mentioned. The Wikipedia article on "Mass in general relativity", here...
http://en.wikipedia.org/wiki/Mass_in_general_relativity
...has the following interesting statement:
"In a way, the ADM energy measures all of the energy contained in spacetime, while the Bondi energy excludes those parts carried off by gravitational waves to infinity."
Wald (1984) is referenced. I have seen statements like this elsewhere as well. Given the definition of ADM mass vs. Bondi mass, this makes sense: ADM mass involves picking a spatial 3-surface out of the spacetime, doing an integral over a 2-sphere in that 3-surface, and taking the limit as the 2-sphere goes to spatial infinity (or, equivalently, as the radius of the 2-sphere goes to infinity). That means that, even if a system is emitting gravitational waves, those waves are still somewhere on any given 3-surface, so they will eventually be contained within the 2-sphere of integration as the radius of the 2-sphere goes to infinity, and hence the energy carried by the waves will be "counted" in the ADM mass. (Since the ADM mass integrand involves the metric coefficients, not the stress-energy tensor components, the wave energy is unproblematically accounted for even though the waves are in vacuum, i.e., zero SET.)
The Bondi mass, on the other hand, evaluates a similar integral at future null infinity, so the gravitational waves will "escape" from the region that is being integrated over, and hence their energy will not be "counted" in the Bondi mass. So in order to determine whether a particular asymptotically flat spacetime is radiating GWs or not, one would compare the ADM mass to the Bondi mass and see if there is a difference.
This also helps clarify what Birkhoff's Theorem is saying: for Schwarzschild spacetime, the ADM mass and Bondi mass are equal, so any spacetime that is isometric to Schwarzschild spacetime outside some finite radius r (which applies to any spherically symmetric spacetime with an exterior vacuum region, by BT) will also have both masses equal, and therefore can't contain any GWs.
  • #132
This agrees with my understanding of all this.
  • #133
First bit is just what I argued back in #1 - spherical symmetry means cancellation of momentum flow terms. I invited comment, none came. So one presumes that is accepted as true. Second part is surely far from correct - just look at the Komar expression in #1. Stress just adds scalar-like. Arbitrarily tiny radial motions cannot on any reasonable measure make stress disappear as source. But no-one else wants to tackle the matter in those similar terms for all contributions. And it seems evidently futile to persist, there just are no takers.
And here is my problem. I keep asking for evaluation via the 'charge/potentials' route - SET contributions for specific geometry and motions etc. All I get back is - we only use the approved 'field approach' formula which doesn't look at it in those terms.
  • #134
Of course not, but what in turn is so hard to grasp with seeking to look at it in terms of individual SET contributions in the given time varying situations, all in the very weak field regime. None of you will have a bar of it and I can't see why. No such reticence to do the equivalent in EM exists afaik, and why should it.
So is there some accessible version of ADM that can be simply applied to the shell case - one where the difference to Komar expression is readily apparent?
  • #135
DaleSpam said:
Q-reeus: "Given motion is invalidating Komar, it must be because certain SET terms behave differently under radial motion, agreed?"
That is an explanation, or merely a statement begging further questions?
  • #136
A non-stationary spacetime does not have any timelike Killing vectors, and the timelike Killing vector is part of the definition of the Komar mass. See the Wikipedia page that you linked to in the OP.
I.e. the problem with the Komar mass is not due to "certain SET terms", it is due to the missing Killing vector.
  • #137
As position statement that's now been said often enough. What is not said once is just where and how and how much it would fail for the case of e.g. vibrating shell.
So it is generally believed for GR, but there are experts of a different opinion, even if in a small minority. But this is just sophistry either way.
  • #138
I don't think that presumption is justified. Many of your assertions have not been responded to, but I think the other commenters in this thread would agree with me that silence does *not* imply consent. :rolleyes:
However, since you mention this specific point, I went back and took a look at what I think is the relevant portion of #1:
Q-reeus said:
For the momentum-energy flux terms Ti0 = -T0i, having radial acting velocity vector character, spherical symmetry implies net cancellation.
First of all, the SET is symmetric, not antisymmetric, so Ti0 = T0i, with no minus sign. Second, I don't see how spherical symmetry implies net cancellation of *all* such terms. Spherical symmetry would imply that there is no net *tangential* momentum flow, yes, but spherical symmetry imposes no such constraint on *radial* momentum flow; that does not have to cancel.
So I was right, silence did not imply consent on that point.
Since I'm already posting anyway, I'll respond briefly to your other statement as well:
Not sure what you mean by this. Radial momentum flow can certainly contribute to *changing* stress, which does change how much stress is present to be a source.
  • #139
From #1: "My contention is that if normal stresses truly are a source for gravitating mass m, it implies the following:"
No subsequent claim by me of a rigorous proof of anything, anywhere. Always cast as 'if such and such is true, it implies such and such. And I have invited all the way along to be picked up on any specific point of error - note the word specific. OK use of Komar mass came up, but no attempt to put a finger on where in that expression things were going wrong or why, or to what degree. Just 'can't use it - live with it - just accept BT is true - end of story'. Not terribly satisfactory imo. Why is it so hard to put the finger on precisely where it fails? Does it fail gracefully and in a highly predictable and quantifiable manner, or just implodes at the slightest sign of time variation? No-one it seems can say for sure - it's undefined and that's that.
  • #140
An interesting passage indeed Peter - as an aside here reminds me of our discussions in another thread over 'gravity gravitating' or not. There I mentioned Clifford Will was on record saying that 'gravity is a source of further gravitation', but couldn't then find the reference. Did subsequently, it's in sect. 4.3, 3rd para. at http://relativity.livingreviews.org/Articles/lrr-2006-3/fulltext.html
"In GR, the gravitational field itself generates gravity, a reflection of the nonlinearity of Einstein’s equations, and in contrast to the linearity of Maxwell’s equations." Too bad I couldn't quote it back then, not that appeals to authority are worth much anyway.
Right but that seems to be top down definitions to me. What would really impress is knowing what BT enforces about the specific behavour of SET terms for say the shell of #1. Knowing that would clear up much, but it seems beyond the reach of anyone.
9K
