PAllen
- 2,610
Q-reeus said:Let's say this is correct. It should be possible then to pinpoint where the balance between a varying Komar mass and non-varying ADM mass is taken up. Given motion is invalidating Komar, it must be because certain SET terms behave differently under radial motion, agreed? So what are these motion dependent terms that compensate in a spherical geometry? Can we at least drill down that far? It's what I've basically been asking from the start. If SET terms acting as suggested above cannot be identified, then it follows there really are extra SET terms de facto introduced. For instance, if time-rate-of-change of a 'standard' SET term becomes a source, that becomes a distinctly different SET term. I'm talking here about 'new' SET terms - clearly radial motion of mass constitutes an energy-momentum flow there, which is just a standard SET term. Rate of change of that would not be. Anyone say otherwise?
This doesn't make any sense to me. There is no concept of SET terms changing meaning that needs to be explained. There is just a specialized formula that can be used of none of the terms of T is time varying. Is this concept so hard to grasp? Instead, you can use ADM mass always - it applies to dynamic as well as stationary spacetimes. Any concept of directly relating terms of T to gravitational mass is wrong.
