Is the Book Right? Examining Conservation of Momentum
The discussion centers on the conservation of momentum in a scenario involving a moving carriage and a student. The proposed solution calculates the speed of the carriage after the student jumps out, using momentum equations. The original book's solution is questioned for potentially neglecting the relative velocity aspect. Participants highlight the importance of proper notation and the correct application of momentum principles. Ultimately, the poster acknowledges a mistake in their calculations after receiving feedback.
phantomvommand
This is a problem from 200 Puzzling Physics Problems.
A student and ticket collector of mass m are in a stationary railway carriage of mass M. The collector realises the student has no ticket, so the student runs towards the end of the carriage, and the collector chases after him with speed v relative to the carriage. The student stops at the end of the carriage and jumps out. Find the velocity of the carriage when the collector stops at the open end of the carriage and watches the student escape.
My proposed solution:
When the student stops at the end, suppose the carriage is moving at speed u.
0 = (M+2m)u - m(v - u)
==> u = mv/ M+3m
After jumping out, the total momentum of the Carriage + collector system is 0 - mu = -m^2v/ M+3m.
By conservation of momentum for the Carriage + collector system, at the time when the collector stops at the open end:
-m^2v/ M+3m = 0 + (M+m)V, where V is the final velocity of the carriage + collector.
V = -m^2v/ (M+3m)(M+m)
The book (200 Puzzling Phys Problems) writes that the speed of the carriage when the student has reached the end and stopped (but not yet jumped) is u = mv/M+2m.
I suppose this is from the Conserve momentum equation: (M+2m)u = mv. Doesn't this forget the fact that v is a relative velocity?
Is the book right, and why am I wrong?
Thank you!
==> u = mv/ M+3m
1) your lack of using brackets will cause errors -- if not now, then later
2) Your momentum balance should not have the ticket collector on both sides, but: ticket collector on one side and carriage + student on the other.
Likes phantomvommand
I see my mistake now, thank you very much!
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
