PAllen
- 2,550
rede96 said:If we take the SR example of the 2 rocket ships mentioned, if there is a taut, thin rope tied between them, if the rocket ships recede, the rope breaks. This is invariant in that every FoR will see the rope break. There is no FoR that will see the rope slacken. The rope, in the way I am understanding this, represents the proper distance between the two ships. In that if all frames of reference took turns in measuring the rope in their own FoR, they would all measure the same length.So if there is a FoR that uses a specific coordinate system which measures the 2 rocket ships to be approaching each other, but observe the rope breaking, then it seems to me that the way the rockets are being measured is in error. If there are many ways to measure something but they all give a different result, they all can't be correct in terms of the proper distance.
Is that not correct?
No, it is almost as if you are choosing not to understand what I write. I will try again:
You are correct that the rope will break in all frames if it breaks in one. You are wrong that this requires the proper distance to increase in all frames. The proper distance cannot be defined without a space time slicing, and different slicings will have the rockets approaching rather than receding. Both cases are proper distance. The rope's tension is measuring expansion scalar (effectively) not proper distance. What you are missing is that in the inertial frame, the rope itself will be shrinking in length as measured in this frame, and the rockets will be getting closer together, but the exact rate of acceleration I specified for the rockets means the rope will be under increasing tension and will break. I have specified a situation where the length contraction of the [of the unstressed] rope [would] occur slightly faster than the distance between ships decrease, so the rope breaks in the inertial frame due to differential between these two shrinkages (the length the rope 'wants to be' versus the distance between the ships, both decreasing).
