mitchell porter
- 786
mitchell porter said:Judging by a combination of empirical success and empirical predictiveness, I'd say holographic QCD is the best thing to come out of string theory,
I meant the part of holographic QCD that models hadron masses and couplings, e.g. this recent paper claims success in modeling rho and omega meson decays, and makes glueball predictions. The work on QGP seems to me less grounded and more qualitative, more about learning to model holographically the complicated phase diagrams of QCD-like theories. btw there was a new twist on QGP holography released today.JorisL said:If I'm not mistaken the empirical success has become less significant when reaching higher energies e.g. for the case of a quark-gluon plasma.
In some models, it's not what you expect. For example, suppose that the quark-Higgs yukawa interactions (that generate the quark masses once the Higgs field develops a nonzero energy density) are all the same size in some basis - this is called "democratic" and it has been a common hypothesis, inspired among other things by how the BCS model for superconductivity works. A democratic matrix has one very large eigenvalue and two very small eigenvalues, so this implies one heavy quark and two light quarks. Then you need to suppose that there is an extra, "radiative" contribution to the light quark masses, from heavy particles in virtual loops. According to this 1992 study (see the very end), in some models this is enough to explain why down is heavier than up - because of how the radiative corrections work out.David Neves said:In the second and third generation of fermions, the quark with 2/3 charge is heavier than the quark with -1/3 charge. If that were also true in the first generation, which you would logically expect to be the case since that's the pattern,
In evolution they talk about proximate and ultimate causes. The proximate cause of a plant growing towards the light might be enzymes (auxins and expansins). The ultimate cause if that if it doesn't, it will die. So natural selection produced an organism with a mechanism capable of implementing that imperative. The relation between a model like the democratic radiative theory of quark mass, and anthropic reasoning, might be the same.
