I Is the uncertainty principle applicable to single slit diffraction?
  • I
  • Thread starter Thread starter greypilgrim
    Diffraction Slit
greypilgrim
Hi.
I've seen single slit diffraction being brought up as an example of the uncertainty principle: Narrowing the slit restricts the particles more in one dimension, which means the momentum in this dimension is more uncertain, which results in a more spread-out diffraction pattern.
I've even seen "derivations" of the uncertainty relation like the following:
They use the 1st minimum of the pattern to define ##\Delta\vec{p}_x##, and then with ##\sin(\alpha_1)\approx\tan(\alpha_1)## and the de Broglie wavelength successfully arrive at ##\Delta x\cdot\Delta p_x\approx h##.
Well just taking the 1st minimum seems arbitrary. But if I'm not mistaken, a correct derivation of ##\Delta p_x## diverges since ##x^2\sinc^2 (x)## isn't integrable. This of course doesn't contradict the uncertainty principle, but is there a more rigorous way to make sense of it in the case of the single slit?
It's kind of weird that this "spreading out" of the pattern while narrowing the slit isn't reflected in ##\Delta p_x## at all which is always infinite.
Hi,
Not a real answer, but:
The colleagues have a thread on your subject.
There is also Sheet 24 here
The uncertainty principle is a quick way to justify diffraction, but it doesn't explain the detail. A more detailed explanation is:
When the particle reaches the slit it has effectively the uniform wavefunction of a plain wave. The slit acts like an infinite square well and the wavefunction transforms to a linear combination of momentum eigenstates appropriate to the width of the well. When it emerges from the well, that superposition evolves as a superposition of free particle states. The width of the central band corresponds to the ground state of the well. The narrower the slit, the wider the band. The other bands correspond to the excited states. For a wider slit only the ground state is significant. For a narrow slit, more of the excited energy states become significant.
That's still some way short of a full mathematical treatment. But, it explains more than simply invoking the UP.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
