Is the Universe Infinitely Old and What Would We Expect to See?
  • Thread starter Chronos
  • Tags
    Universe
In summary, assuming the universe is infinitely old, it would be expected to see the same things we see now. There is an infinite number of ticks since the Big Bang if time is measured on a logarithmic scale, but this definition of time has no correspondence to what we normally understand to be the "age" of something. If gravity wins, everything will end up in a supermassive black hole, and if it doesn't, the universe will become an infinitely thin, 0K gas. The properties of compressed space under the effect of gravity are unclear and it is unknown if it is occupiable by matter. Time is intimately connected to the atomic clock, which measures the same time that governs aging and other functions. A hypothetical clock
  • #36
Just for the record, I see many problems with an infinitely [temporally] old, compared to a finitely old universe. The question is this... If you accept the proposition the universe is infinitely old, what observational differences should we expect from one that is not? PS, I'm intentionally avoiding introducing Olber's paradox [a very powerful argument] into this hypothesis.
Astronomy news on Phys.org
  • #37
Footnote: what really bothers me about this is you need steady state creation of 'new' matter to replace the 'old' matter that is consumed by stellar fusion. Where is the evidence of this? How is it more convenient to assume continuous creation of new matter, than a one time 'poof' incident? The 'poof' version seems easier to swallow. In that scenario you can at least claim the laws of physics had not yet kicked in. My last question is how do you explain why the CMB is not infinitely energetic?
  • #38
To be the devils advocate - The CMB can be attributed to the new matter. That would be evidence. Also the CMB is not infinitely energetic because we only get a taste of it once, by way of the new matter, which is a finite sum. In this scenario there would be a center to the universe, and we would be close to it. Also in this scenario - All matter that is made eventually appears to be close to center in a universe that evolves outward from a central point.
Not that this is the case, but it is within the realm of possibilities.
  • #39
I disagree. Do the math that shows new matter emerges from that scenario. That will impress me.
  • #40
In a linearly coasting model, where are the coasting redshift galaxies? The obvious answer ... there aren't any. So we back we go to the question: where are the high redshift galaxies superimposed in front of the low redshift galaxies? OMG, there aren't any! Arpians claim there is at least one such example... but amazingly avoid the discussion why there are not thousands of them.
  • #41
We don't know where the energy for the BB came from either, but that never stopped anyone from looking for the answers.
  • #42
Can't say I follow your question.
  • #43
Ask ST, he has a better explanation than I.
  • #44
I'm guessing you were making an assumption as to how the galaxies would look in the scenerio I mentioned, but I would say they will look like they do now ( increasing redshift over distance).
  • #45
A good question. I'm just saying we live in a temporally finite universe. Everything appears to age, hard to explain that in a universe that does not age.
  • #46
It goes to the bigger question... the Fermi paradox. Where are they? The answer, in my opinion, is you can't get here from there.
  • #47
If you read my posts carefully you will see that I subscribe to two different ways of measuring the universe. With c a constant of nature in both, one has a 'photonic' clock and one has an 'atomic' clock as defined in my post #29.
We can define two physically significant times as follows:
Sample two photons, one emitted by a caesium atom the other sampled from the CMB radiation.
The first, an "atomic" second, is defined as the duration of exactly 9.19263177x109 periods of the radiation corresponding to the transition between the two hyperfine levels of the ground state of the caesium 133 atom.
The second, a "photonic" second, is defined as the duration of exactly 1.604x1011 periods of the radiation corresponding to the peak of the CMB black body spectrum.
Both systems of time measurement are physically significant and agree with each other in the present time, although they will diverge from each other at other times.
When compared to the atomic standard, the "photonic" clock in the linearly expanding model, extrapolated back to the earliest moments of the BB, diverges to (-) inifinity as atomic time t->0.
Thus in this model we can recover "an infinitely old universe" within an apparently finite (as measured by an "atomic" clock) BB paradigm.
The system that uses the 'atomic' clock' is that in SCC's Einstein conformal frame in which the universe is linearly expanding from a BB about 14 Gyr ago. Its advantage over the Mainstream model is that it does not require exotic DM or DE to be concordant, also as we have discussed it gives more time, about twice as much, for early structures to form in the high z ~ 6 - 10 universe, hence my interest in a possible age problem already apparent in the Mainstream model.
It is only in the Jordan conformal frame which uses 'photonic' time that the universe is eternal and static. Here atomic processes in the early universe are seen in slow motion but the physics is the same as before, only 'slower'.
It is not a Steady State or equivalent theory where matter/star/galaxies have to be regenerated. The 'slow motion effect' is a consequence of using this method of measuring time.
Galaxies are observed with cosmological red-shift, in the linearly expanding Einstein frame, which is interpretated as a Doppler effect;, in the static eternal Jordan frame it is interpreted as a mass-field effect.
I do not understand what you mean by "coasting galaxies", except the general understanding of GR that all galaxies are understood to be coasting along their geodesics through cosmological space-time.
In the linear expansion model as red-shift is cosmological, due to the universe's linear expansion, there should be no high z objects in front of low z ones.
I hope this has helped.
Garth
  • #48
A question for Garth:
Is your measure of the age of the universe equivalent to the "affine distance" along a light-like geodesic from "now" to the "big bang"? (Converted to units of seconds).
Affine distance is defined in the following URL
http://relativity.livingreviews.org/open?pubNo=lrr-2004-9&page=articlesu4.html
I think it should be, because I think the affine parameterization of a light beam should "count wavelengths".
  • #49
I concur pervect; the affine distance depends on the 4-velocity of the observer.
The age of the universe as measured by two different observers passing each other at speed will depend on their velocities relative to the Surface of Last Scattering, the observer co-moving with the SLS having the greatest age.
Thank you for that link.
Garth
  • #50
Garth said:
I concur pervect;
On second thoughts ...
I will have to consider this further.
But only in the Einstein conformal frame with a finite age.
I am questionning what happens in the Jordan frame. Perhaps it is only for the "observer co-moving with the SLS" that the universe's age diverges...
The question is:"How is the ruler used in the affine parametrization [itex]s \rightarrow \lambda(s)[/itex] itself calibrated in distant regions?"
Garth
