I Is the weak field limit valid for the Brans-Dicke scalar field?
  • I
  • Thread starter Thread starter p78653
    Scalar field
p78653
The Brans-Dicke theory is a scalar-tensor modification of general relativity that has been tested against solar system experiments which show that the parameter implying that the theory is almost indistinguishable from GR.
These tests assume the weak field limit of the theory so that the scalar field .
But is this valid if the scalar field is long range so that all the mass in the Universe at any distance contributes to at any given point in space?
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
