The discussion clarifies that the symbol for micro (10^-6) is indeed represented by the Greek letter mu (μ). It points out that a common error occurs when the symbol for "proportional to" (∝) is mistakenly used instead of mu. In cases where TeX is unavailable or Greek letters are hard to type, some people substitute "u" for mu, such as using "uF" to denote microfarads. The conversation emphasizes the importance of using the correct symbol to avoid confusion. Accurate representation of scientific symbols is crucial for clear communication in technical contexts.
#1
Nway
34
I am confused about a notation highlighted shown below
C = Q/V
Can someone tell me what that means? I'm think it should be a mu.
If TeX is not available and Greek letters are difficult to type people sometimes use "u" instead (uF = ##\mathrm{\mu F}##). The "proportional to" (\propto, ##\propto##) is just the wrong symbol.
Kindly see the attached pdf. My attempt to solve it, is in it.
I'm wondering if my solution is right. My idea is this: At any point of time, the ball may be assumed to be at an incline which is at an angle of θ(kindly see both the pics in the pdf file). The value of θ will continuously change and so will the value of friction.
I'm not able to figure out, why my solution is wrong, if it is wrong .
TL;DR Summary: I came across this question from a Sri Lankan A-level textbook.
Question - An ice cube with a length of 10 cm is immersed in water at 0 °C. An observer observes the ice cube from the water, and it seems to be 7.75 cm long. If the refractive index of water is 4/3, find the height of the ice cube immersed in the water.
I could not understand how the apparent height of the ice cube in the water depends on the height of the ice cube immersed in the water. Does anyone have an...
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame?
I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
