Is there anything more to forces than being mathematical machinery?
In summary, classical physics tells us how to compute the forces acting on a body due to another body and how different parts of the system move under the action of those forces. However, it does not provide a direct explanation of what forces are. They can be seen as a mathematical abstraction of more fundamental interactions that cause motion between particles. The concept of force may have been introduced as a means to an end in formulating laws of physics and calculating results, but there is still a lack of understanding about the true nature of forces and how they are transmitted. Some have suggested that forces may be caused by a constant agent acting according to certain laws, but the exact nature of this agent is still unknown. Ultimately, the concept of force is necessary for understanding
  • #36
DrStupid said:
The definition of forces says that they are proportioanl (or equal if you use proper units) to change of momentum.
That is pretty close to my preferred definition: “force is the rate of transfer of momentum”. Since momentum is a conserved quantity it’s makes sense to speak of transferring it. Both Newton’s 2nd and 3rd laws follow directly from that definition.
Edit: I see you said as much in a subsequent post!
Likes Marc Rindermann, weirdoguy and etotheipi
  • #37
Just for curiosity, how do you define mass? Something like volume times density would be tautological.
  • #38
Historically, it had been defined in terms of another standard mass, using things like balance scales -- forces and torques as proxies for mass under the assumption of a locally uniform gravitational field. [One can also use spring compression as a proxy for force and make assumptions about temporally uniform gravitational fields and linear and unchanging spring properties].
The idea being that two bricks have twice as much mass as one. Or that a lump of platinum irridium over here that balances with a lump of platinum irridium over there must have the same mass.
The underlying assumptions about linearity, uniformity, and such have been well tested for millenia. Commerce and commercial advantage is a powerful motivator.
  • #39
I would define mass operationally. Something like “mass is the quantity measured by a balance scale”. This is similar to how time is defined.
Likes etotheipi
  • #40
In that case wouldn't you have to define a uniform gravitational field or equivalent since the balance scale doesn't work very well in free space?
  • #41
DrStupid said:
I am quite sure that it is ment like that because Newton repeated it in the first law of motion. A force is required to change the state of motion but it is not sufficient. Several forces and the corresponding changes of momentum (and therefore also the resulting accelerations) can add to zero.
Yes. The way you stated it there makes sense and takes care of my concern.
  • #42
Only if you do not insist on a limitation of Newton III to two-body forces because that does not follow directly from the interpretation of force as transfer of momentum :wink:.
  • #43
In classical mechanics it is indirectly given by the definition of momentum, Newton II + III, the principle of relativity, isotropy and the transformation. (But be careful: If you use this definition in relativity you get something that is like a red rag to a bull for physicists.) I do not know if it also works without isotropy. It is at least required in the one-dimensional case.
Is is a tautology today because we use this definition the other way around to define density. I do not think that was the case when Newton defined mass this way centuries ago. It provides at least a general impression what mass is and what it not is (e.g. amount of substance, which is sometimes confused with Newtons term "quantity of matter").
  • #44
I would leave details like that for the manufacturer of the balance scale to explain in the owner’s manual. I would not make it part of the definition.
  • #45
I still strongly disagree with your take on that topic but have less than 0 interest in renewing a discussion on it.
Likes weirdoguy
  • #46
Lack of gravity is not a problem encountered in typical use but artificial gravity (e.g. rotation) can readily be employed if needed. The Acme balance scale, orbital version, has the requisite information in appendix B.
  • Haha
Likes Dale and FactChecker
  • #47
etotheipi said:
It doesn't really tell you what the forces are though.
I don't think this is anything more than a way of communicating a shared experience with other people - same as any other piece of language. You can draw up a list of effects that can be attributed to the result of a "force'. The introduction of Maths into it makes no fundamental difference; Maths just improves the precision of communication between people and allows more reliable 'reasoning'.
You and I (I'm assuming) had similar educations so we can communicate about a process that involves what we both call "a force" by using Newton's Laws of Motion. If you try to build up knowledge about the World without using Science, you end up with statements like "Nature abhors a vacuum" and we know that seriously falls short when you want to build a rocket or a radio set.
Otoh, if you want to get all philosophical then you need to go elsewhere than PF for your answers.
Likes etotheipi
  • #48
etotheipi said:
I do apologise, that wasn't the intent of my OP! If the best answer is that force is a quantity defined as ##m\mathbf{a}##, I would consider that a perfectly good answer.
That is only part of the answer. Consider ##F = ma##. This is not that physically meaningful until we say what ##F## is. ##F## is a push or a pull - an interaction - between two (or more) bodies, with the strength and direction of the push or pull being dependent on the properties of both bodies.
In the case, of gravitation, the relevant properties of the bodies are their masses: ##F = Gm_{1}m_{2}/r^{2}##
In the case of the electrical force (in electrostatic situations), the relevant properties of the bodies are their charges: ##F = Kq_{1}q_{2}/r^{2}##
Combining the electrostatic force law with Newton' second law gives ##Kq_{1}q_{2}/r^{2} = ma##, which shows that the properties of bodies that determine how they interact (ie. the LHS of ##F=ma##) do not necessarily involve the inertial mass (in the RHS of ##F=ma##).
In the case of the gravitational force, the property on the LHS is called the gravitational mass. Amazingly, in the unique case of the gravitational force, a body's gravitational mass (on the LHS) is always proportional to its inertial mass (on the RHS). This coincidence is one form of something called the Principle of Equivalence, which inspired Einstein's approach to General Relativity, a relativistic theory of gravity. Reformulated versions of the Principle of Equivalence hold in General Relativity.
Likes etotheipi
  • #49
etotheipi said:
Really then, it appears that introducing the concept of forces is just a means to an end (i.e. you formulate your laws of physics using the construction of 'forces' and can start calculating results), since we could cut them out and just say that the interaction between particles causes motion (though admittedly it would be rather more complicated to calculate anything...). This might well be a stupid question, but is there a physical underlying motivation for introducing forces, or are they just a mathematical abstraction of the more fundamental interactions?
The concept of force is the way the interactions are described in elementary Newtonian physics. In relativity, and especially relativistic quantum mechanics, the force concept of Newton is not so useful. But although we no longer use the mathematical formalism of Newton in those cases, we still call the interactions between bodies "forces".
And yes, even classically you can get rid of forces eg. the Hamiltonian and Lagrangian formalisms.
Likes etotheipi
  • #50
Good point BUT I very seldom come across a situation where my body tells me I'm dealing with Potential Energy, rather than with Forces.
I've had many useful conversations with young teenagers about the 'nature' of Forces and Energy and they clearly aren't ready for any more than what our experiences of those two things involves. To my mind, that implies that we start off with lists of what effects can be put down to Force or Energy. I have never been asked (at that level) what they 'really are'.
Many people want to fill in that gap between the totally intuitive / subjective experience and the mathematical model by looking for a 'really is' model. But, without the Maths, the 'really is' is little more than a dressed up version of intuition.
Likes etotheipi and vanhees71
  • #51
As I see it, the force found its existence due to the philosophy of causation. Its hard to think that motion can be caused without any cause. And we see that due to this philosophy we something called "Fictitious Forces", these fictitious forces do not exist (no one is there to cause them) but the motion is caused so we have to accept their existence.
  • #52
I think that is a very tenuous position to hold given Newton’s first law
Likes nasu
  • #53
Where you say "motion", you really should be saying "acceleration". In a Newtonian inertial coordinate system, there is no unexplained acceleration. The "fictitious forces" are there to allow us to study acceleration in non-Newtonian coordinate systems. It is just a computational convenience with no philosophical implications.
  • #54
In the context of this discussion, I would say that N1 is no more than a self referential statement. It more or less says that All Things behave like this. No real causality is implied.
  • #55
According to N1 force is the cause and the change of motion the effect. How is this not a causality?
Likes Adesh
  • #56
I thought that Newton's first law is just a statement that there exist inertial frames of reference in which objects remain at rest or in constant rectilinear motion if no forces act on them. I think that's along the lines of what @sophiecentaur was saying (correct me if I'm wrong!).
  • #57
I usually refer to the original wording. That reads in the English translation:
Every body persists in its state of being at rest or of moving uniformly straight forward, except insofar as it is compelled to change its state by force impressed.
That means that forces are the only cause for changes in the state of motion of bodies. Frames of references are not even mentioned.
Likes Adesh
  • #58
I think those are really the original words.
  • #59
Right, but the notion of an inertial reference frame is implied. If you sit in a car that accelerates, everything outside the window will accelerate backward without any real forces being applied.
I just treat the first law as the definition of an inertial frame of reference.
  • #60
Nevertheless this holds only for inertial frames of reference. The 1st Law rather states that there are reference frames, where this 1st Law holds, the inertial frames. Then the 2nd Law says that the causes of changes of the state of motion (the deviation from rectilinear uniform motion) are forces, which are equal to ##\dot{\vec{p}}##, where for a point particle ##\vec{p}=m \vec{a}## with ##m## a measure for inertia ("inertial mass") and ##\vec{a}## the acceleration of the particle relative to the inertial reference frame.
  • #61
Not usually the best approach. The ideas have been polished and refined since Newton first stated them.
A more modern view is that cause and effect are irrelevant. If there is a change of momentum, there is a net force. If there is a net force, there is a change of momentum. The two concepts are not cause and effect -- they are more nearly synonymous. We adopt the definition that a "force" is a transfer of momentum and that an "inertial frame" is one in which Newton's first law holds good.
Likes weirdoguy and russ_watters
  • #62
That’s what I believe and have found that same expression expressed by some other well known physicists (including you).
Likes etotheipi
  • #63
You mean Newton? He's pretty well known, I guess. :wink:
  • Haha
Likes Adesh
  • #64
Mr. Feynman, Mr. Arnold Sommerfeld and few others too.
Likes vanhees71
  • #65
Science has ‘identified’ a common but rather slippery intermediate agency - a Force- which takes the place of all other real agencies: horses, falling water, a spring, a magnet etc.. The term Force allows us a common concept that can be treated a bit like money. We can earn money from many sources and spend it in many ways. Maths is what helps us deal with quantities involved. You could say that the causality is between the tennis player and the ball and the force just allows you to appreciate the quantities involved.
Our brains treat both forces and money as if they are real but they’re only in your head. I thing this justifies the OP and you can choose validly to look at things that way.
Likes etotheipi
  • #66
Since the OP has been answered and this thread is now veering off into a repetition of a discussion that was previously closed it is time to close this thread also.
Likes etotheipi
