B Is time an illusion?
  • B
  • Thread starter Thread starter L Drago
    Einstein Time
L Drago
TL;DR Summary
According to Einstein, time is relative.
According to Einstein's relativity, all intertial frame of motion is relative and time is also relative. Let's consider Person A is sitting on a chair and is at rest with respect to surface on Earth and Person B is travelling in 80 percent speed of light with respect to planet Earth and Person C travelling at 90 percent speed of light with respect to planet Earth. Time dilation will be different for these three observers. Dilated time = Actual time / power root of (1-(v²/c²)). Dilated time is different for these. Time is the fourth dimension and curvature in that Space time coordinate is also caused my mass and GR time dilation can be observed.
Hence, is time just an illusion and the distinction between the past, the present and future is also but a stubborn illusion?
  • Skeptical
Likes PeroK
L Drago said:
TL;DR Summary: According to Einstein, time is relative.
Einstein did not say that time is relative, he said that simultaneity is relative. The time along any timelike worldline is invariant and in no way relative; and anything else that we call "time" cannot be directly measured but only calculated based on assumptions about simultaneity.
And speaking of time.... It is really way past time for you to stop posting and start studying so that you will know what you're talking about when you do post.
Likes Orodruin, phinds and robphy
In relativity there are two different types of time. One is called coordinate time, and the other is called proper time.
Coordinate time is the one that is relative. I wouldn’t call it an illusion. I would call it a convention.
Proper time is invariant. It is not relative and all observers and frames agree on it. It is physical and measurable. I wouldn’t call it an illusion either.
The causal past and future of any given event is also an invariant physical fact. The present of any event is a convention, which I again would not call an illusion either.
Likes russ_watters, Orodruin and robphy
Motion and time are equivalent categories.
Without time, movement cannot be defined.
Time cannot be defined without movement.
If time is an illusion then motion is also an illusion.
I can hardly imagine any philosophical concept in which movement is only an illusion.
Edit:
If time is an illusion, then motion is also an illusion.
The activity I am currently engaged in, typing, is a kind of movement.
So this post of mine is just an illusion. Wow ...
  • Skeptical
Likes jbriggs444 and Motore
No. All inertial frames are equivalent, all time is not relative. The time I measure on my wristwatch, for example, is the same for all regardless of their inertial motion. As I told you before, you have to think in terms of events and the intervals that elapse between them. You can't be an armchair commentator without understanding the play-by-play.
Word for word the same comment you recently made in another thread. You ignored my responses there and now you just parrot the same comment.
What do you mean by actual time? Between what events are you measuring the dilated time by Persons B and C? Can you give us a specific example with the calculated times? This is what I'm talking about when I tell you you can't be an armchair commentator without understanding the play-by-play.
A word salad.
No. Leave out the "hence" and you have paraphrased one or two of Einstein's quotes, but by including the word "hence" you are implying that you know what led him to those conclusions. In truth, it's not clear to scholars what he meant by those philosophical statements. It is certainly presumptuous by you or anyone else to claim you know what physics led to them. It may in fact be that there is none, and Einstein felt no need for there to be any.
Note: Edited for clarity.
Likes ferxz10
This thread is now closed.
Likes renormalize
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
