- #36
Austin0
- 1,160
- 1
Austin0 said:Like everyone here , when I saw Ich's solution I thought it was a clever approach to the question and concluded it was a done deal.
2) Even if this assumption should be correct it still ignores the physics and measurement in the Earth frame.
In that frame it is very simple:
...A point on the track is chosen located at the top of the rear drive wheel ,as the tank moves forward that point is tracked until it is located on top of the front drive wheel.
If you apply the distance traveled according to the .74844 figure and then apply contraction on top of this you get a track point (segment) that has not traveled as far as the wheel base and gearing. The contraction figure for the base is .8930 and for the track is .6632.
SO either something is amiss or the track should decompose.
Austin0 said:There are the additional questions; in the tank frame both the top and bottom are moving and so would be equally contracted.
In the Earth frame the top would be contracted but not the bottom .
Austin0 said:Given: ...Ich's velocity figure is totally accurate.
....The other effects are in operation, the tank and track is contracted etc.
....We now are measuring the track velocity.
....We start with a coordinate time and position measurement at the rear point on the track where it is equivalent to the rear wheel base.
...We take another measurement at the point where it is colocated with the topmost point of the front wheel (and base)
...From these two points we derive velocity for the track point and the wheel base.
...The distance traveled by the track is simply dx=dxt
...for the wheel base it is dx-(wheel base...dx)=dxb
...I think it is safe to say that geometrically dxt=2 dxb
...Using round geared wheels and geared track the forward motion of the base is [tex]\pi[/tex]x 2r(radius of wheel) per revolution. The top track must advance by twice this value to maintain continuity with the wheel base and gear teeth.[/B
...Velocity .For the track this is simply dxt/dt=vt
For the base it is ...dxb/dt=vb
If we assume that vt <vb then either
...1)....dxt<2 dxb
or ...2)...dtt >dtb
,,,,,,,,,,,,,Considering there are only 2 measurements.. t1-t0=dt
,,,,,,,,,,,,Number 2) is not not very viable.
This is pure kinematics . What is measured after the physics is already in effect.
Ich said:First, a comment:
Yes, the tank frame is preferred: It's the only one where beginners have a nonzero chance of even guessing the right result. .
As a pedagogical preference I wouldn't disagree but there is the 1st P to consider also.
Ich said:The most important thing in learning relativity is to tell the difference between logic and preconception. In the rest frame, many preconceptions happen to coincide with what the logic actually tells us. So if you get different results, most likely both are wrong, but the one derived in the moving frame is certainly wrong.
COmplete agreement regarding preconception i.e. intuitive logic as it applies to learning SR.
But there is the logic that applies within SR and also applies to SR as a logical theoretical structure.
Specifically testing its derivative applications regarding consistency with the fundamental structure.
Please do not try to twist this around into some kind of questioning of SR.
My world view is founded on both the logical consistency of the fundamental structure as elucidated by A Einstein as well as its total validity as a description of the real world.
Rock Solid
The term moving frame is normally simply an operative term. With the implicit understanding that both frames are "moving" dependiong on perspective.
Agreed ;within the tank frame.Ich said:Now for the math.
The tank is moving at v=0.45 (I use c=1, that's easier). That's not a question, that's the setup.
In the tank frame:
The ground has v=-.45 by some basic principles, and since the lower track is at rest wrt the ground it has v=-.45, too.
Now imagine a virtual vertical plane separating the rear part from the front part of the tank. Call it the middle plane.
Now there's an equation of continuity that says that, in any given timespan, as many track segments have to cross said plane from back to forth as in the other direction, lest the segments accumulate somewhere.
From symmetry principles it is evident that v=0.45 for the upper track fulfills the continuity condition. It can be shown mathematically that this is the only solution.
.Ich said:This is not entirely trivial, however.
For example, the segments all like to be Lorentz-contracted. If you have a fixed number of (well-fitting) segments and spin up the tank, this cannot be achieved. Either the track will break, or the segments all get stretched. You could also add more segments until the track fits again.
Austin0 said:...A point on the track is chosen located at the top of the rear drive wheel ,as the tank moves forward that point is tracked until it is located on top of the front drive wheel.
Ich said:Ok, now we've established v_upper = 0.45 in the tank frame, and v_tank = 0.45 in the ground frame, we have that formula that tells us that v_upper in the ground frame is 0.74844. This is not up to debate. That's dictated by logic, and if you have some logic that says otherwise: it's wrong.
I am not sure what you are referring to when you say "is not up for debate" or what "logic "you are referring to.
If you mean the formula given those v's,, returns 0.74844 I certainly never questioned it.
If you mean the "logic" that was behind the velocity in the tank frame then I never questioned that either
Austin0 said:I have absolutely no question that Ich's math was accurate as was the logic of Newtonian mechanics he applied in the tank frame.
If you mean the logically derived conclusion is not up to debate then I would have questions.
As far as I know the domain of applicability of the Addition of Velocities equation is limited to ;
Independant inertial frames or objects.
a) The track as a whole or as segments would not seem to be inertial.
It is under constant acceleration through force.
b) The track is not independant. It is physically connected to both the tank and the ground.
I don't just mean in contact but that the physics of both frames have direct causal effects.
SO it would seem there is doubt if it would apply to this situation at all.
This would seem to then raise some doubt whether the derived figure can be taken at its normally , factual value , without further ocnsideration.
Since I never made any assertion at all as to the quantitative relative velocity from the ground frame I am unsure how I could have gone "wrong"Ich said:I don't know where all of you went wrong in the "moving" (=ground) frame, but here's a description that at least gives the correct result. It's a convoluted argument, but that's always the case if you think in terms of the ether: time dilation and length contraction.
Ich said:Here's the point where some of you see the continuity equation violated, and claim that logic dictates both closing speeds be the same (up to the sign). It's easy to show how this is wrong.
How many segments ("n") do actually move from back to forth and otherwise in, say, 1 second?
Use some algebra to find that n = v/l * 1 second, where v is the closing speed and l the length of a segment.
The lower track is at rest in the ground frame. The're no relativity to be obeyed, and for the sake of simplicity we set the length of a segment in that frame to be 1 second. (Remember, c=1. If you want to use the usual dimensions: that means l = 1 lightsecond = ~300000 km.)
Then n_lower = 0.45/1 s = -0.45/s.
The upper segments are slower (lower absolute closing velocity), but contracted and thus more densely packed. From the Lorentz contraction formula, we get: l_upper = 0.6632 s.
And we find n_upper = 0.29844/0.6632 s = 0.45/s.
Austin0 said:...Using round geared wheels and geared track the forward motion of the base is [tex]\pi[/tex]x 2r(radius of wheel) per revolution. The top track must advance by twice this value to maintain continuity with the wheel base and gear teeth.
I absolutely never made any such claiim that both speeds must be the same.
Given your contraction figures which I am sure are accurate:
This would mean that not only the links were contracted but, if we assume gearing, then the number of links between wheels would be fixed and so the distance between the tops of the wheels would also have to be contracted relative to the ,bottom of the track, distance between the bottoms of the wheels. Yes??
WOuldn't you assume this would create intolerable stress on the wheels??
And wheelbase??
Would you maintain that this was a workable reality by the same criteria you applied to the tank frame??
.Ich said:What a surprise, if it works in the rest frame, the math somehow magically conspires to make it work in a moving frame, too.
That's not a coincidence, it's a mathematically proven property of relativity. Whenever you find it violated, you got something wrong. To repeat: you got something wrong, not relativity and not the international conspiracy of pysicists.
Whenever it doesn't work, seek you error, and don't take your flawed logic for granted and insist the the others have to be wrong.
Austin0 said:...I am sure you can take Ich's calculations to the bank
Ich said:Edit: The last sentences appear somehow harsh, and they are not aimed at you, Ken Natton, and only partially at Austin0 (more from the experience in a different thread, I'd say you, Austin0, can make use of this advice.).
Which part of the advice? If you mean your international conspiracy; please spare me.
If you mean my flawed logic please point to a specific point of my logic and show me.
Not this blanket assumption and ad hominem assertion.
As applied to me this whole post is directed at claims I never made .
This also applies to the other thread you referred to. I never came to conclusions or made assertions regarding the problem. I never said everyone was wrong outside of a final logical argument with someone. I made an error, not of logic, but of perspective and recognized it in the thread. As the majority of the thread was not regarding the actual problem but simply dickering over the boundary conditions which I acceeded to , I fail to see how any of the above applies. Once again if you think there are flawed points of logic or any assumptions not consistent with the principles of SR fine. Bring them forth. I am ready to learn.
