I Kerr & Nordström Black Hole Evaporation: Q&A
snorkack
When a Kerr black hole evaporates, what will the Kerr parameter do?
Stay constant at initial value?
Approach zero?
Approach unity?
Approach a target value somewhere between zero and unity?
Also, Nordström black holes in practice (with matter around) would have a strong tendency to attract charged plasma. But in perfect vacuum? How strong would the leak current out of a Nordström black hole be? Quantum mechanics suggests a tail of tunnelling in strong electric fields. At which charge would a Nordström black hole be evaporating at constant q/m, if the dependence of q on m is that simple? And does the mathematics of Nordström black hole expressly depend on electron rest mass?
snorkack said:
the Kerr parameter
What do you mean by the Kerr parameter?
The expression
Jc/GM2
where J is angular momentum, c speed of light, G gravitational constant and M the mass of the hole.
It is bound to be between zero (it is Schwarzschild hole) and unity for any black hole.
How does it evolve on Hawking radiation?
If you search "Hawking evaporation Kerr BH" you find a good number of reputably published papers discussing this. At the moment, I don't have time to quick read them to try to choose the most informative.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
